  3. 0ne or Four Byte Address Test Fail
0ne or four byte address test fail
By rajacms , 4 March, 2021
Dear mikko,
how can identified 0ne or four byte address
following condition not satisfied. server allow to connect all conditions
Logical addr. Phy addr. Adressing Method connection Est
0 1 1byte YES
1 1 1byte NO
0 256 1byte NO
1 256 1byte YES
0 1 4byte NO
1 1 4byte NO
0 256 4byte NO
1 256 4byte YES
no difference one and four byte server address
//Check server address with one byte.
if (((serverAddress & 0xFFFFFF00) == 0 && (serverAddress & 0x7F) == it->id) ||
//Check server address with two bytes.
((serverAddress & 0xFFFF0000) == 0 && (serverAddress & 0x7FFF) == it->id))
ret = 1;
break;
5 years 4 months ago
You can modify svr_isTarget for your needs. We are updating the example server that can handle four bytes addressing where the logical address is one and the physical address is 256 in next week.
This is done so it's easier to implement Indian-standard.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
