  3. Failed To Read 0.1.99.98.2.255, Attribute 2. Insufficient Memory
Failed to Read 0.1.99.98.2.255, attribute 2. Insufficient memory
By MNN , 16 February, 2021
Gurux.DLMS.AMI
An error occurs when reading the event log 0.1.99.98.2.255:
Reading: 0.1.99.98.2.255
TX: 04:48:16 7E A0 4C 03 0F 32 0D DA E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 D0 01 01 FF 00 00 00 00 00 00 00 09 0C 07 E5 02 10 FF 11 00 00 FF FF 4C 00 01 00 3E C4 7E
RX: 04:48:16 7E A8 89 0F 03 52 A6 BA E6 E7 00 C4 01 C1 00 01 06 02 03 09 0C 07 E5 02 10 02 10 0C 38 FF FF 4C 00 09 09 01 C2 D2 AD 28 25 27 4E 3F 06 00 41 3A BC 02 03 09 0C 07 E5 02 10 02 10 10 22 FF FF 4C 00 09 09 02 FD 6D FB A9 41 DC E8 6B 06 00 41 3A BD 02 03 09 0C 07 E5 02 10 02 10 13 34 FF FF 4C 00 09 09 01 9F 35 F7 24 01 08 37 F0 06 00 41 3A BE 02 03 09 0C 07 E5 02 10 02 10 15 1B FF FF 4C 00 09 09 00 6D 85 70 14 8B D6 7E
TX: 04:48:16 7E A0 07 03 0F 51 32 5D 7E
RX: 04:48:16 7E A0 52 0F 03 54 DD BD 22 18 80 5C 06 00 41 3A C0 02 03 09 0C 07 E5 02 10 02 10 17 14 FF FF 4C 00 09 09 00 FB 70 DC 71 87 72 65 55 06 00 41 3A C1 02 03 09 0C 07 E5 02 10 02 10 18 1A FF FF 4C 00 09 09 02 76 89 97 56 67 83 B7 2D 06 00 41 3A C2 AB 9C 7E
+fail: Gurux.DLMS.AMI.Reader.ReaderService[0]
Failed to Read 0.1.99.98.2.255:2. Insufficient memory to continue the execution of the program.
TX: 04:48:16 7E A0 19 03 0F 74 7E 46 E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 03 00 EF 0B 7E
RX: 04:48:16 7E A0 48 0F 03 76 C2 A0 E6 E7 00 C4 01 C1 00 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 73 09 06 00 00 13 28 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 13 32 00 FF 0F 02 12 00 00 A1 F9 7E
TX: 04:48:16 7E A0 19 03 0F 96 62 82 E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 04 00 E7 46 7E
RX: 04:48:17 7E A0 15 0F 03 98 2B F0 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
TX: 04:48:17 7E A0 19 03 0F B8 1E 4A E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 05 00 3F 5F 7E
RX: 04:48:17 7E A0 12 0F 03 BA 1A A5 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
TX: 04:48:17 7E A0 19 03 0F DA 0A 0A E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 06 00 57 75 7E
RX: 04:48:17 7E A0 22 0F 03 DC D8 EF E6 E7 00 C4 01 C1 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19 7E
TX: 04:48:17 7E A0 19 03 0F FC 3E 4E E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 07 00 8F 6C 7E
RX: 04:48:17 7E A0 15 0F 03 FE 1B F6 E6 E7 00 C4 01 C1 00 06 00 00 00 06 4B 7D 7E
TX: 04:48:17 7E A0 19 03 0F 1E 22 8A E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 08 00 47 EF 7E
RX: 04:48:17 7E A0 15 0F 03 10 6B F8 E6 E7 00 C4 01 C1 00 06 00 00 00 0A 27 B7 7E
In Director reading without errors:
16:50:36 Read object type ProfileGeneric index: 4
TX: 7E A0 19 03 0F 32 4C 61 E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 04 00 E7 46 7E
16:50:36
RX: 7E A0 15 0F 03 52 7D 99 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
16:50:36 Read object type ProfileGeneric index: 5
TX: 7E A0 19 03 0F 54 7C 67 E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 05 00 3F 5F 7E
16:50:36
RX: 7E A0 12 0F 03 74 68 8A E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
16:50:36 Read object type ProfileGeneric index: 6
TX: 7E A0 19 03 0F 76 6C 65 E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 06 00 57 75 7E
16:50:36
RX: 7E A0 22 0F 03 96 86 02 E6 E7 00 C4 01 C1 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19 7E
16:50:36 Reading profile generic data 0.1.99.98.2.255
TX: 7E A0 19 03 0F 98 1C 6B E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 02 00 37 12 7E
16:50:36
RX: 7E A8 89 0F 03 B8 F2 F2 E6 E7 00 C4 01 C1 00 01 06 02 03 09 0C 07 E5 02 10 02 10 0C 38 FF FF 4C 00 09 09 01 C2 D2 AD 28 25 27 4E 3F 06 00 41 3A BC 02 03 09 0C 07 E5 02 10 02 10 10 22 FF FF 4C 00 09 09 02 FD 6D FB A9 41 DC E8 6B 06 00 41 3A BD 02 03 09 0C 07 E5 02 10 02 10 13 34 FF FF 4C 00 09 09 01 9F 35 F7 24 01 08 37 F0 06 00 41 3A BE 02 03 09 0C 07 E5 02 10 02 10 15 1B FF FF 4C 00 09 09 00 6D 85 70 14 8B D6 7E
16:50:36
TX: 7E A0 07 03 0F B1 3C BA 7E
16:50:37
RX: 7E A0 52 0F 03 BA AD B3 22 18 80 5C 06 00 41 3A C0 02 03 09 0C 07 E5 02 10 02 10 17 14 FF FF 4C 00 09 09 00 FB 70 DC 71 87 72 65 55 06 00 41 3A C1 02 03 09 0C 07 E5 02 10 02 10 18 1A FF FF 4C 00 09 09 02 76 89 97 56 67 83 B7 2D 06 00 41 3A C2 AB 9C 7E
16:50:37 Read object type ProfileGeneric index: 7
TX: 7E A0 19 03 0F DA 0A 0A E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 07 00 8F 6C 7E
16:50:37
RX: 7E A0 15 0F 03 DC 0B F4 E6 E7 00 C4 01 C1 00 06 00 00 00 06 4B 7D 7E
16:50:37 Read object type ProfileGeneric index: 8
TX: 7E A0 19 03 0F FC 3E 4E E6 E6 00 C0 01 C1 00 07 00 01 63 62 02 FF 08 00 47 EF 7E
16:50:37
RX: 7E A0 15 0F 03 FE 1B F6 E6 E7 00 C4 01 C1 00 06 00 00 00 0A 27 B7 7E
MNN
5 years 9 months ago
Hello.
Hello.
Base SQLITE is used. Can you help? I can provide an extended log from AMI.
We can't repeat this. Can you send your GXDLMSDirector device file to me by email?
MNN
I sent you an email with a
I sent you an email with a file.
Thanks.
MNN
5 years 8 months ago
Hello.
Hello.
Did you receive the letter? Did you reproduce the problem?
  • Victorian | WA 083148835648
