  3. Introducing Gurux DLMS/COSEM For Java Micro Edition
Introducing Gurux DLMS/COSEM for Java Micro Edition
By Administrator , 23 July, 2018
Gurux DLMS for ME
Gurux DLMS/COSEM for Java Micro Edition is a protocol component, whose purpose is to offer an easy-to-use component for Java ME developers, to communicate with energy measuring devices.
With this component, you can easily create your own data collecting systems, to build an Automatic Meter Reading system (AMR), to meet your specific needs.
If You have any questions, problems, or suggestions, concerning Gurux DLMS/COSEM for Java ME, kindly, post a message at the forum.
Joel Amenya
6 years 9 months ago
Hey guys, I'm relatively new
Hey guys, I'm relatively new here. I'm looking for resources to help me get started in building my AMR solution in java. I will appreciate any link to useful resources to help me integrate to gurux dlms library
Hi Joel,
Hi Joel,
You should check the client example from GitHub.
https://github.com/Gurux/gurux.dlms.java
Another option is that you use the REST API and use Gurux.DLMS.AMI.
www.gurux.fi/Gurux.DLMS.AMI
I believe that Gurux.DLMS.AMI can be good option for you if you don't know meter reading very well.
Akash kumar
5 years 8 months ago
I am completely new can you
I am completely new can you please guide where to start for ANDROID step by step.
In reply to I am completely new can you by Akash kumar
Hi Akash,
Hi Akash,
You should check this:
I have to warn you that DLMS is not an easy protocol and it might take some time to get started.
I suggest that you install GXDLMSDirector and play with it first.
Akash kumar
Gurux GXDLMSDirector could
Gurux GXDLMSDirector could not connect to created device and throws this error
No connection can be made as target machine actively refused it
Akash kumar
In reply to Hi Akash, by Kurumi
Ok thank you
Ok thank you
In reply to Gurux GXDLMSDirector could by Akash kumar
Hi Akash,
Hi Akash,
Your TCP/IP port or address is wrong.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
