  3. DLMS Conformance Test Fail Report
DLMS Conformance test Fail report
By rajacms , 23 February, 2021
i am using DLMS ANSI C library in my meter.
We based following Conformance test issue.
please help me how to close this issue
please find out log
DLMS Conformance test report
19-FEB-2021 11:15:55
CTT 3.1 standard edition, 64bits, release 107
* Summary *
TYPE TOTAL SKIPPED INAPPLICABLE INCONCLUSIVE PASSED FAILED
* HDLC Tests *
T_HDLC_FRAME_N5
1: Unknown command identifier FAILED(Response not FRMR)
T_HDLC_ADDRESS_P1
1: One byte address FAILED(No response to SNRM)
T_HDLC_INFO_N3
Wrong N(S) sequence number FAILED(Response not RR)
* APPL Tests *
T_APPL_IDLE_N1
0/0, ServerSAP = 1, ClientSAP = 16, LONG_NAMES, NO_SECURITY
Data exchange in IDLE state PASSED
T_APPL_OPEN_1
1.Establish an AA using the parameters declared FAILED(Unexpected negotiated conformance)
0/1, ServerSAP = 1, ClientSAP = 32, LONG_NAMES, LOW_LEVEL_SECURITY
1.Establish an AA using the parameters declared FAILED(Unexpected response to AssociationRequest)
T_APPL_OPEN_4
1. Protocol-version present and containing the
default value FAILED(Association could not be established)
T_APPL_OPEN_6
1: Unused AARQ fields are present with a dummy
value FAILED(Association is not "accepted")
value INAPPLICABLE(AA not public)
2: AARQ.calling-AP-title too short INAPPLICABLE(AA not ciphered or not using GMAC)
3: AARQ.calling-AP-title too long INAPPLICABLE(AA not ciphered or not using GMAC)
4: AARQ.calling-AE-invocation-id present when
client user identification is not supported FAILED(Association is not "accepted")
T_APPL_OPEN_7
1: AFU absent FAILED(Invalid class typecast)
T_APPL_OPEN_11
xDLMS-Initiate.request: quality-of-service FAILED(Association could not be established)
T_APPL_OPEN_12
1: proposed-dlms-version-number = 5 PASSED
2: proposed-dlms-version-number = 7 FAILED(Association could not be established)
T_APPL_OPEN_13
1: Propose all services and capabilities in line
with the application context FAILED(Association could not be established)
T_APPL_OPEN_14
xDLMS-Initiate.request: max-receive-pdu-size PASSED
T_APPL_DATA_LN_N4
Unsupported service (LN) FAILED(Unexpected negotiated conformance)
T_APPL_REL_P1
1: Graceful release in HDLC profile FAILED(Unexpected negotiated conformance)
* COSEM Tests *
- FAILED(Unexpected negotiated conformance)
log files
Serial[1] 0'00.456 +345327 Opened
Serial[1] 0'00.496 +39 7EA00A0002040121537B737E
Serial[1] 0'00.699 +203 7EA00A21000204011FC43D7E
Serial[1] 0'01.494 +795 7EA00A00020401219377B57E
Serial[1] 0'01.742 +247 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 0'01.761 +19 7EA00A0002040121116D127E
Serial[1] 0'01.869 +108 7EA00A210002040111BAD47E
Serial[1] 0'01.893 +23 7EA00A0002040121537B737E
Serial[1] 0'02.038 +145 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 0'02.930 +892 7EA00A0002040121537B737E
Serial[1] 0'03.024 +94 7EA00A21000204011FC43D7E
Serial[1] 0'03.937 +912 7EA00A00020401219377B57E
Serial[1] 0'04.067 +130 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 0'04.067 +0 7EA00A0002040121537B73
Serial[1] 0'04.181 +113 7EA00A0002040121116D127E
Serial[1] 0'04.695 +513 7EA00A210002040111BAD47E
Serial[1] 0'04.715 +20 7EA00A0002040121537B737E
Serial[1] 0'04.859 +143 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 0'05.723 +864 7EA00A00020401219377B57E
Serial[1] 0'05.957 +233 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'19.794 +133836 7EA00A0002040121537B737E
Serial[1] 2'19.920 +126 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'20.827 +906 7EA00A0002040121537B737E
Serial[1] 2'20.909 +81 7EA00A21000204011FC43D7E
Serial[1] 2'21.838 +929 A00A00020401219377B57E
Serial[1] 2'23.860 +2022 7EA00A00020401219377B5
Serial[1] 2'25.888 +2027 A00A00020401219377B5
Serial[1] 2'27.924 +2036 7EA00A0002040121537B737E
Serial[1] 2'28.009 +84 7EA00A21000204011FC43D7E
Serial[1] 2'29.009 +1000 7EA00A0002040121537B737E
Serial[1] 2'29.080 +71 7EA00A21000204011FC43D7E
Serial[1] 2'29.981 +900 7EA009020401219377B57E
Serial[1] 2'32.002 +2021 7EA0080401219377B57E
Serial[1] 2'34.017 +2014 7EA00701219377B57E
Serial[1] 2'36.033 +2016 7EA006219377B57E
Serial[1] 2'38.047 +2014 7EA0059377B57E
Serial[1] 2'40.063 +2016 7EA00477B57E
Serial[1] 2'42.118 +2054 7EA003B57E
Serial[1] 2'44.205 +2086 7EA0027E
Serial[1] 2'46.233 +2028 7EA00A00020401219377B57E
Serial[1] 2'46.696 +463 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'46.745 +48 7EA00A0002040121537B737E
Serial[1] 2'46.916 +171 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'47.890 +973 7EA00A0002040121537B737E
Serial[1] 2'47.988 +97 7EA00A21000204011FC43D7E
Serial[1] 2'48.873 +885 7E000A00020401219377B57E
Serial[1] 2'50.889 +2015 7EA00A0002040121537B737E
Serial[1] 2'50.975 +85 7EA00A21000204011FC43D7E
Serial[1] 2'51.991 +1016 7EA00A0002040121537B737E
Serial[1] 2'52.102 +110 7EA00A21000204011FC43D7E
Serial[1] 2'52.975 +873 7EA00B00020401219377B57E
Serial[1] 2'54.996 +2021 7EA00A0002040121537B737E
Serial[1] 2'55.086 +89 7EA00A21000204011FC43D7E
Serial[1] 2'56.061 +975 7EA00A00020401219377B57E
Serial[1] 2'56.805 +744 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'56.808 +2 7EA00A0002040121FF1D1C7E
Serial[1] 2'56.930 +121 7EA012210002040130148FE6E700D80202CF5B7E
Serial[1] 2'57.028 +97 7EA00A0002040121537B737E
Serial[1] 2'57.182 +154 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 2'58.013 +831 7EA02100020401219476A0818012050180060180070400000001080400000001533B7E
Serial[1] 3'00.058 +2044 7EA00A0002040121537B737E
Serial[1] 3'00.694 +636 7EA00A21000204011FC43D7E
Serial[1] 3'01.142 +447 7EA00A0002040121537B737E
Serial[1] 3'01.588 +445 7EA00A21000204011FC43D7E
Serial[1] 3'02.132 +544 7EA02100020401219376A0818012050180060180070400000001080400000002533B7E
Serial[1] 3'04.182 +2049 7EA00A0002040121537B737E
Serial[1] 3'04.696 +514 7EA00A21000204011FC43D7E
Serial[1] 3'05.276 +579 7EA00A0002040121537B737E
Serial[1] 3'05.586 +309 7EA00A21000204011FC43D7E
Serial[1] 3'06.267 +680 7EA0070321930F017E
Serial[1] 3'08.402 +2135 7EA00A0002040121537B737E
Serial[1] 3'08.688 +285 7EA00A21000204011FC43D7E
Serial[1] 3'09.386 +698 7EA00B0002040100219361807E
Serial[1] 3'11.399 +2012 7EA00A0002040121537B737E
Serial[1] 3'11.638 +239 7EA00A21000204011FC43D7E
Serial[1] 3'12.536 +897 7EA00A00020401219377B57E
Serial[1] 3'12.717 +181 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'12.724 +7 7EA007052193D6D77E
Serial[1] 3'14.827 +2103 7EA00A000400052193629F7E
Serial[1] 3'16.884 +2056 7EA00A0002040121537B737E
Serial[1] 3'17.088 +203 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'18.460 +1372 7EA00A0002040121537B737E
Serial[1] 3'18.642 +182 7EA00A21000204011FC43D7E
Serial[1] 3'19.510 +867 7EA00A0002040121537B737E
Serial[1] 3'19.640 +130 7EA00A21000204011FC43D7E
Serial[1] 3'20.494 +854 7EA0090002052193AFD07E
Serial[1] 3'22.505 +2010 7EA00A0002040121537B737E
Serial[1] 3'22.640 +134 7EA00A21000204011FC43D7E
Serial[1] 3'23.570 +929 7EA00B0002040001219306C67E
Serial[1] 3'25.597 +2027 7EA00A0002040121537B737E
Serial[1] 3'25.682 +84 7EA00A21000204011FC43D7E
Serial[1] 3'26.730 +1047 7EA00A0002040121537B737E
Serial[1] 3'26.828 +98 7EA00A21000204011FC43D7E
Serial[1] 3'27.701 +873 7EA017000204012193F12E818008050207EE060207EE529E7E
Serial[1] 3'27.955 +253 7EA02321000204017314B6818014050207EE060207EE070400000001080400000001B5D47E
Serial[1] 3'27.997 +42 7EA00A0002040121537B737E
Serial[1] 3'28.175 +177 7EA02321000204017314B6818014050207EE060207EE070400000001080400000001B5D47E
Serial[1] 3'29.076 +901 7EA00A0002040121537B737E
Serial[1] 3'29.607 +530 7EA00A21000204011FC43D7E
Serial[1] 3'30.056 +448 7EA01B0002040121936B9F81800C07040000000408040000000496FB7E
Serial[1] 3'30.701 +645 7EA02321000204017314B6818014050207EE060207EE070400000004080400000004BB737E
Serial[1] 3'30.754 +52 7EA00A0002040121537B737E
Serial[1] 3'30.931 +177 7EA02321000204017314B6818014050207EE060207EE070400000004080400000004BB737E
Serial[1] 3'31.829 +898 7EA00A00020401219377B57E
Serial[1] 3'31.982 +152 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'31.983 +1 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 3'32.220 +236 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 3'32.272 +52 7EA00A0002040121537B737E
Serial[1] 3'32.750 +477 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'33.270 +519 7EA00A00020401219377B57E
Serial[1] 3'33.638 +368 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'33.640 +1 7EA810000204012110C672E6E60060E1B47E
Serial[1] 3'33.745 +104 7EA00A210002040131B8F57E
Serial[1] 3'33.747 +2 7EA810000204012112D4511DA1090684587E
Serial[1] 3'33.838 +91 7EA00A210002040151BE967E
Serial[1] 3'33.841 +2 7EA810000204012114E2340760857434627E
Serial[1] 3'33.952 +111 7EA00A210002040171BCB77E
Serial[1] 3'33.955 +2 7EA810000204012116F017050801014B577E
Serial[1] 3'34.125 +170 7EA00A210002040191B2507E
Serial[1] 3'34.129 +3 7EA8100002040121188EFEBE10040EDA337E
Serial[1] 3'34.631 +501 7EA00A2100020401B1B0717E
Serial[1] 3'34.632 +1 7EA81000020401211A9CDD0100000034EB7E
Serial[1] 3'34.713 +81 7EA00A2100020401D1B6127E
Serial[1] 3'34.714 +1 7EA81000020401211CAAB8065F1F044C257E
Serial[1] 3'34.815 +100 7EA00A2100020401F1B4337E
Serial[1] 3'34.817 +1 7EA81000020401211EB89B0060FEDFA03A7E
Serial[1] 3'34.915 +98 7EA00A210002040111BAD47E
Serial[1] 3'34.917 +1 7EA00E000204012110926CFFFF660C7E
Serial[1] 3'35.130 +213 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 3'35.182 +51 7EA00A0002040121537B737E
Serial[1] 3'35.688 +506 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'36.320 +631 7EA00A00020401219377B57E
Serial[1] 3'36.752 +432 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'36.754 +2 7EA0FD000204012110AD530000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000020137E
Serial[1] 3'37.092 +338 7EA00A21000204019784357E
Serial[1] 3'37.094 +1 7EA00A00020401219377B57E
Serial[1] 3'37.633 +539 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'37.690 +56 7EA00A0002040121537B737E
Serial[1] 3'37.860 +169 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'38.748 +888 7EA00A00020401219377B57E
Serial[1] 3'38.893 +144 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'38.894 +1 7EA00A0002040121316F337E
Serial[1] 3'39.000 +106 7EA00A21000204019784357E
Serial[1] 3'39.003 +2 7EA00A00020401219377B57E
Serial[1] 3'39.143 +140 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'39.187 +44 7EA00A0002040121537B737E
Serial[1] 3'39.686 +498 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'40.248 +562 7EA00A00020401219377B57E
Serial[1] 3'40.740 +492 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'40.742 +1 7EA02E000204012112032CE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 3'40.878 +136 7EA00A21000204019784357E
Serial[1] 3'40.927 +49 7EA00A0002040121537B737E
Serial[1] 3'41.128 +200 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'41.992 +863 7EA00A0002040121537B737E
Serial[1] 3'42.091 +98 7EA00A21000204011FC43D7E
Serial[1] 3'42.956 +865 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 3'43.097 +140 7EA00A21000204011FC43D7E
Serial[1] 3'43.098 +1 7EA00A0002040121537B737E
Serial[1] 3'43.485 +386 7EA00A21000204011FC43D7E
Serial[1] 3'44.244 +759 7EA00A00020401219377B57E
Serial[1] 3'44.434 +190 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'44.441 +7 7EA01C000204012110E0EEE6E600C001C1000F0000280000FF0100F9797E
Serial[1] 3'44.651 +209 7EA013210002040130C110E6E7000E01030294A87E
Serial[1] 3'44.737 +86 7EA00A0002040121537B737E
Serial[1] 3'44.879 +142 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'44.905 +25 Closed
Serial[1] 3'46.336 +1431 Opened
Serial[1] 3'46.353 +16 7EA00A00020401219377B57E
Serial[1] 3'46.715 +361 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'46.716 +1 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 3'46.960 +244 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 3'47.049 +88 7EA00A0002040121537B737E
Serial[1] 3'47.696 +647 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'47.716 +19 Closed
Serial[1] 3'49.331 +1614 Opened
Serial[1] 3'49.356 +25 7EA00A00020401419322D07E
Serial[1] 3'49.644 +287 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'49.646 +2 7EA04F0002040141101451E6E600603EA1090607608574050801018A0207808B0760857405080201AC128010434D535F444C4D535F4D455445525F33BE10040E01000000065F1F040060FEDFFFFFF5537E
Serial[1] 3'49.842 +196 7EA012410002040130A508E6E700D80205702F7E
Serial[1] 3'49.995 +152 7EA00A0002040141532E167E
Serial[1] 3'50.171 +175 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'50.200 +29 Closed
Serial[1] 3'51.684 +1483 Opened
Serial[1] 3'51.701 +16 7EA00A00020401219377B57E
Serial[1] 3'51.824 +123 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'51.827 +2 7EA032000204012110420BE6E600602180020284A109060760857405080101BE10040E01000000065F1F040060FEDFFFFFA1717E
Serial[1] 3'52.059 +232 7EA03F210002040130D8C2E6E700612E80020284A109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D0800000704E77E
Serial[1] 3'52.168 +108 7EA00A0002040121537B737E
Serial[1] 3'52.719 +551 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'52.747 +27 Closed
Serial[1] 3'54.171 +1424 Opened
Serial[1] 3'54.196 +25 7EA00A00020401219377B57E
Serial[1] 3'54.688 +492 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'54.691 +2 7EA02E000204012110110FE6E600601DA10906075F857504070203BE10040E01000000065F1F04007C1BA0FFFF8C3B7E
Serial[1] 3'54.909 +218 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020101A305A103020102BE11040F080101065F1F0400001E1D080000071AA57E
Serial[1] 3'55.102 +192 7EA00A0002040121537B737E
Serial[1] 3'55.714 +612 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'55.731 +16 Closed
Serial[1] 3'57.131 +1400 Opened
Serial[1] 3'57.141 +9 7EA00A00020401219377B57E
Serial[1] 3'57.644 +502 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'57.647 +3 7EA047000204012110ADEAE6E6006036A109060760857405080101A203040144A303040144A403020100A503020100A803020100BE10040E01000000065F1F040060FEDFFFFF8FC07E
Serial[1] 3'57.895 +248 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 3'58.053 +157 7EA00A0002040121537B737E
Serial[1] 3'58.697 +644 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 3'58.741 +44 Closed
Serial[1] 4'00.199 +1458 Opened
Serial[1] 4'00.220 +21 7EA00A00020401419322D07E
Serial[1] 4'00.740 +519 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'00.755 +15 7EA07200020401411011A9E6E6006061A109060760857405080101A203040144A303040144A403020100A503020100A703040144A803020100A9030201018A0207808B0760857405080201AC128010434D535F444C4D535F4D455445525F33BE10040E01000000065F1F040060FEDFFFFF19E17E
Serial[1] 4'00.989 +233 7EA012410002040130A508E6E700D80205702F7E
Serial[1] 4'01.129 +139 7EA00A0002040141532E167E
Serial[1] 4'01.671 +541 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'01.697 +26 Closed
Serial[1] 4'03.130 +1432 Opened
Serial[1] 4'03.154 +24 7EA00A00020401419322D07E
Serial[1] 4'03.715 +560 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'03.719 +3 7EA02E000204014110446AE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'03.876 +156 7EA012410002040130A508E6E700D80205702F7E
Serial[1] 4'03.993 +117 7EA00A0002040141532E167E
Serial[1] 4'04.159 +166 7EA0214100020401731E068180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'04.186 +26 Closed
Serial[1] 4'05.666 +1480 Opened
Serial[1] 4'05.679 +12 7EA00A00020401219377B57E
Serial[1] 4'05.772 +92 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'05.773 +1 7EA03F0002040121100D25E6E600602EA109060760857405080101BE21041F010110DED00FC20ABAC1C8AC710699F86833FA0000065F1F040060FEDFFFFF5C717E
Serial[1] 4'05.948 +174 7EA0302100020401302CDBE6E700611FA109060760857405080101A203020101A305A103020101BE0604040E010600CA207E
Serial[1] 4'06.046 +98 7EA00A0002040121537B737E
Serial[1] 4'06.652 +605 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'06.680 +27 Closed
Serial[1] 4'08.110 +1430 Opened
Serial[1] 4'08.131 +20 7EA00A00020401219377B57E
Serial[1] 4'08.727 +596 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'08.729 +2 7EA02F000204012110C490E6E600601EA109060760857405080101BE11040F0100000101065F1F040060FEDFFFFF5D2F7E
Serial[1] 4'08.972 +242 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'09.124 +151 7EA00A0002040121537B737E
Serial[1] 4'09.732 +608 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'09.758 +25 Closed
Serial[1] 4'11.196 +1437 Opened
Serial[1] 4'11.217 +21 7EA00A00020401219377B57E
Serial[1] 4'11.803 +585 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'11.806 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000055F1F040060FEDFFFFFB73A7E
Serial[1] 4'12.050 +243 7EA0302100020401302CDBE6E700611FA109060760857405080101A203020101A305A103020101BE0604040E01060143317E
Serial[1] 4'12.095 +45 7EA00A0002040121537B737E
Serial[1] 4'12.740 +645 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'12.757 +17 Closed
Serial[1] 4'14.178 +1420 Opened
Serial[1] 4'14.199 +20 7EA00A00020401219377B57E
Serial[1] 4'14.687 +487 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'14.689 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000075F1F040060FEDFFFFFF9627E
Serial[1] 4'14.947 +258 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'15.074 +126 7EA00A0002040121537B737E
Serial[1] 4'15.688 +613 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'15.709 +21 Closed
Serial[1] 4'17.177 +1468 Opened
Serial[1] 4'17.191 +13 7EA00A00020401219377B57E
Serial[1] 4'17.661 +470 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'17.663 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'18.015 +352 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'18.153 +137 7EA00A0002040121537B737E
Serial[1] 4'18.679 +526 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'18.692 +13 Closed
Serial[1] 4'20.136 +1444 Opened
Serial[1] 4'20.151 +14 7EA00A00020401219377B57E
Serial[1] 4'20.729 +578 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'20.732 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDF000BB5007E
Serial[1] 4'20.950 +217 7EA0302100020401302CDBE6E700611FA109060760857405080101A203020101A305A103020101BE0604040E01060351127E
Serial[1] 4'21.060 +109 7EA00A0002040121537B737E
Serial[1] 4'21.680 +620 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'21.707 +27 Closed
Serial[1] 4'23.108 +1401 Opened
Serial[1] 4'23.139 +30 7EA00A00020401219377B57E
Serial[1] 4'23.692 +552 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'23.694 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'23.922 +227 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'24.083 +161 7EA00A0002040121537B737E
Serial[1] 4'24.735 +651 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'24.753 +18 Closed
Serial[1] 4'26.197 +1443 Opened
Serial[1] 4'26.238 +41 7EA00A00020401219377B57E
Serial[1] 4'26.686 +447 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'26.688 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'26.921 +232 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'27.494 +572 7EA00A0002040121537B737E
Serial[1] 4'27.668 +173 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'27.690 +22 Closed
Serial[1] 4'29.140 +1449 Opened
Serial[1] 4'29.161 +20 7EA00A00020401219377B57E
Serial[1] 4'29.636 +475 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'29.640 +3 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'29.855 +215 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'30.001 +145 7EA00A0002040121537B737E
Serial[1] 4'30.106 +104 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'30.128 +21 Closed
Serial[1] 4'31.618 +1490 Opened
Serial[1] 4'31.637 +18 7EA00A00020401219377B57E
Serial[1] 4'31.800 +162 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'31.802 +2 7EA02E000204012110110FE6E600601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFFDE4E7E
Serial[1] 4'32.026 +223 7EA03B210002040130AEADE6E700612AA109060760857405080101A203020100A305A103020100BE11040F080101065F1F0400001E1D08000007EF417E
Serial[1] 4'32.090 +64 7EA00A0002040121537B737E
Serial[1] 4'32.760 +669 7EA021210002040173AF818180120501F00601F0070400000001080400000001F9CB7E
Serial[1] 4'32.783 +23 Closed
rajacms
5 years 8 months ago
Any update about ctt test issue. if you need any other logs files...
Please help me i need to submit again for ctt test..
rajacms
checked above issue any updates available
There is a new version released today that will fix a few issues, but it seems that there are some problems with _CTI configuration file. You need to check that those match.
Example T_APPL_OPEN_1 fails because the configuration file is not correct.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
