  3. Error Starting Gurux.DLMS.AMI (Guid.Parse)
Error starting Gurux.DLMS.AMI (Guid.Parse)
By abu3bdullah , 14 January, 2021
Gurux.DLMS.AMI
I have the following error starting DLMS.AMI with all default values for appsetting.json
RestAddress: http://localhost:64881
Database type: SQLite
Connecting: Data Source=:memory:
Creating tables.
Service started: http://localhost:64881
Reader trace level is Verbose
Listener trace level is Verbose
Unhandled exception. System.ArgumentNullException: Value cannot be null. (Parameter 'input')
at System.Guid.Parse(String input)
at Gurux.DLMS.AMI.Reader.ReaderService..ctor(ILogger`1 logger, IOptions`1 optionsAccessor, IHostApplicationLifetime applicationLifetime) in C:\vsts-agent\_work\6\s\Gurux.DLMS.AMI\Reader\ReaderService.cs:line 76
abu3bdullah
5 years 10 months ago
Here the constructor of the
Here the constructor of the ReaderService Class, requires 3 arguments:
ReaderService(ILogger<ReaderService> logger, IOptions<ReaderOptions> optionsAccessor, IHostApplicationLifetime applicationLifetime)
But when adding the service "ReaderService" to the host, nothing is passed:
services.AddHostedService<ReaderService>();
This line is missing from last version of "Startup.cs":
services.Configure<ReaderOptions>(Configuration.GetSection("Reader"));
Regards
Thank you for this info. You are right on this. The open source version is now fixed.
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
