  3. Bluetooth Probe Integration For DLMS Meters
Bluetooth Probe integration for DLMS meters
By SarbjitSingh , 15 May, 2019
Gurux DLMS for Android
I want to know how to perform a GXDLMSSecureClient and other functions through bluetooth socket in android.
Sarbjit Singh
7 years 1 month ago
You need to send generated bytes over Bluetooth by your self. GXDLMSSecureClient doesn't care how you send or receive bytes.
SarbjitSingh
7 years 1 month ago
Thanks for your quick
Thanks for your quick response.
Actually I have my serial code as below:
public void readDLMSPacket(byte[] data, GXReplyData reply)
throws Exception {
if (data == null || data.length == 0) {
return;
reply.setError((short) 0);
Object eop = (byte) 0x7E;
Integer pos = 0;
boolean succeeded = false;
ReceiveParameters<byte[]> p = new ReceiveParameters<>(byte[].class);
p.setAllData(true);
p.setEop(eop);
p.setCount(5);
p.setWaitTime(WaitTime);
synchronized (serial.getSynchronous()) {
while (!succeeded) {
serial.send(data, null);
if (p.getEop() == null) {
p.setCount(1);
succeeded = serial.receive(p);
if (!succeeded) {
// Try to read again...
if (pos++ == 3) {
throw new RuntimeException(
"Failed to receive reply from the device in given time." + GXCommon.bytesToHex(p.getReply()));
Log.i("gurux.dlms", "Data send failed. Try to resend "
+ pos.toString() + "/3");
// Loop until whole DLMS packet is received.
while (!secureClient.getData(p.getReply(), reply)) {
p.setCount(1);
if (!serial.receive(p)) {
// If echo.
if (reply.isEcho()) {
if (++pos == 3) {
throw new Exception(
"Failed to receive reply from the device in given time2." + GXCommon.bytesToHex(p.getReply()));
if (reply.getError() != 0) {
if (reply.getError() == ErrorCode.REJECTED.getValue()) {
Thread.sleep(1000);
readDLMSPacket(data, reply);
} else {
throw new GXDLMSException(reply.getError());
There are a few functions which are serial specific. I am unable to convert them for socket. If I send the bytes directly to socket. I get the same response as the request.
Your help would be deeply appreciated.
Thanks & Regards,
Sarbjit Singh
7 years 1 month ago
It depends on what kind of BlueTooth device you are using. If Bluetooth device implements socket you can use network media. I believe that you need to make own media for Bluetooth.
SarbjitSingh
7 years 1 month ago
Sir,
Sir,
We are using BLE with the help of a bluetooth probe. We are using BluetoothGattCallback for sending and receiving request. Can you please give an example or any idea on how to implement GXDLMS with this.
Thanks !
Sarbjit Singh
7 years 1 month ago
I believe best way to go is if you create new media. Select GXNet as template and change open, close, send and receive methods to communicate with your Bluetooth. In this way you don't need to change anything from the example. Othere option is that you made changes for the example for sending and receiving bytes over Bluetooth.
SarbjitSingh
7 years ago
Hello Sir,
Hello Sir,
I am still stuck with the BLE communication with the DLMS meter. On sending the request to the BLE I am receiving junk hex values. Please help me with this.
Thanks !
Sarbjit Singh
SarbjitSingh
7 years ago
Hello Sir,
Hello Sir,
Thanks !
Sarbjit Singh
7 years ago
Hello Sir,
Hello Sir,
What kind of data you are sending and receiving? Can you paste sent and received hex strings here?
SarbjitSingh
7 years ago
Sir,
Sir,
This the authentication request:
7E A0 07 03 41 93 5A 64 7E
I am sending it through GXDLMSSecure client as:
secureClient = new GXDLMSSecureClient(true, 32, 1, Authentication.LOW, "XXXX", InterfaceType.HDLC);
I am giving you the converted response.
Sarbjit Singh
7 years ago
The request is correct. What is the reply?
SarbjitSingh
7 years ago
Sir,
Sir,
Please see the attached screenshot after last 7E. I am receiving that response with error.
Thanks !
Sarbjit Singh
7 years ago
Can you print reply as hex string?
SarbjitSingh
7 years ago
Sir,
Sir,
Please see the response in hex below the error message in attached screenshot.
Sarbjit SIngh
7 years ago
This is the echo. This is not a reply from the meter. You have sent this data.
hurani
6 years 7 months ago
Any Update? I am interested!
Please sir, share the source code you trying to build
6 years 6 months ago
We have made a video about how you can read your meter using Bluetooth from Raspberry PI.
http://www.gurux.fi/bluetooth
itcoder
5 years 6 months ago
In reply to Any Update? I am interested! by hurani
Did you happen to get an
Did you happen to get an example of this hurani?
sandeep007
5 years 5 months ago
I need to communicate with Energy meter which is integrated with BLE module. Need some basic functionality, In BLE module there are different Services, Characteristics(For Read, Write, Notify). I need to Write the data and read from energy meter. Please let me know as soon as possible. I need to develop Android mobile application.
Thanks in Advance.
In reply to Hi, by sandeep007
Hi Sandeep,
Hi Sandeep,
