  3. The Schedule Does Not Work
The schedule does not work
By MNN , 14 December, 2020
Gurux.DLMS.AMI
Hello.
There are 2 problems.
1. In the AMI after 12.10 the schedule stopped working: when the attribute is set to read on a schedule, the task does not start (the time when the schedule starts is not changed).
2. AMI (version 6.10) running on Windows, the schedule works in it, while if the same ami is run under Linux, the schedule does not work (the time when the schedule starts is not changed).
5 years 11 months ago
What date-time you are using? We can check this after we have this information.
MNN
I'm sorry, it's settled.
I'm sorry, it's settled. There was an error in the system time.
Thank you.
Thanks for letting me know.
  • Victorian | WA 083148835648
