  3. MR and Firmware Associations Not Showing In The US Association
MR and Firmware Associations not showing in the US Association
By Ashok_Chowdary , 11 December, 2020
I given BASE(LowAssociation),BASE(FirmwareAssociation ), in the objects list of the US association.But those are not showing in the us association under ASSOCIATION_LOGICAL_NAME IC15.
similary SecuritySetup also given as like above in the objects list of Us Association those are showing in the US association under IC64.
please help me how to resolve this
5 years 11 months ago
Currest DLMS certificate test verifies that there are two associations visible. The Current association and association that is used for this authentication level. In your case it's US. Low and Firmware associations are removed otherwise DLMS CTT test will fail. For this reason, this is correct behavior.
