  3. Selecting An Optical Probe
Selecting an optical probe
By pbtek , 18 November, 2020
Which optical probe i need to buy to read my energy smart meter landis+gyr zcx e110 ??
5 years 10 months ago
There are a lot of different optical probes available and all don't work well with all the meters.
The best way is if you can buy an optical probe from Landis+Gyr.
Note! This meter is using IEC 62056-21 and not DLMS.
pbtek
user manual
user manual
pbtek
5 years 9 months ago
Can you please tell me (point
Can you please tell me (point in right direction) what exactly i will be able to do with my meter if i use an optical probe from Landis+Gyr and Gurux DLMS Director?
Will i need a Low Authentication level password?
It seems that this meter is using DLMS and you can use GXDLMSDirector.
Each meter is different. There is no standard set of functionality what the meter must implement.
You can usually read basic functionality without authentication. If you need to write anything you need the password. Because we don't have this meter the only way to solve this is if you have an optical probe and you will check what you can do with the meter.
pbtek
Searching the web... all IEC
Searching the web... all IEC Optical Probes are expensive toys.
Decisions, decisions!!
That is true. They are really expensive if you think about what they do. I believe that they sold so small amounts and for that reason, they are so expensive at the moment. I hope that they will drop in the future.
pbtek
oh my god...
oh my god...
Is there any chance for me to fill this form correctly? Can i copy paste the XML?
(i am just planning ahead)
To make it harder there are several different versions from zcxe110. :-)
Is your meter one or three-phase meter? Can you see the DLMS logo on the cover of the meter or is there a "PRIME" label?
pbtek
Ladies and gentlemen may i
Ladies and gentlemen may i present to you... my cute landis! :)
Looks good. If you have the optical cable you "should" be able to read the meter.
There are country differences in the metrics, so I can't say for 100% sure.
pbtek
Any tips to fill the form
Any tips to fill the form correctly to connect with GXDLMSDirector?
If you select Landis+Gyr as the manufacturer you should be able to connect right away.
Change Interface from HDLC to HdlcWithModeE if you are using an optical probe.
pbtek
In GXDLMSDirector Examples
In GXDLMSDirector Examples page and reading the initial settings there are 2 options that i pay attention:
1- Landis+Gyr ZCX 110 R there is a
Note! You must change Server Address type from Byte to UIN32 from
Tools | Manufacturers | Landis+Gyr.
2- Landis+Gyr default settings
Default Low Authentication level password is: 00000000
#1. This is now updated. You can "Server Address size" to 4 in Frame tab.
#2. The meter owner (metering company) might change the password for something else and it's not necessarily the default. If it's changed you still can read the current values and load profile (historical data), but you can't change anything.
pbtek
Name: Landis+Gyr ZCXe110CRU0L3D2.03.S3
Manufacturer: Landis+Gyr
Interface: HdlcWithModeE
Authentication: Low
Password: 00000000
Tab Frame-> Server Address size -> 4
Hostname?? what hostname? localhost? why do i need a hostname?
You try to connect using TCP/IP connection. If you want to read using a serial port, change Media to Serial.
pbtek
..and i need to change the
..and i need to change the Media to Serial. And Select the correct serial port. ok!
thx
pbtek
5 years 8 months ago
after few attempts...
after few attempts with:
Authentication: Low
Password: 00000000
change Media to Serial -> choose correct COM port
If you are using the optical port you need to use HdlcWithModeE and if you are using direct serial port your interface type is HDLC.
L+G meter what we have, are using 1 byte addressing. Why you have changed Server Address size to four?
pbtek
Thu, 11/26/2020 - 09:39#15
i am using an optical port. did lots and lots of attempts... no luck. i am not able to connect.
Can you give more details from the optical probe?
Are you receiving any reply from the meter?
pbtek
Some detais...
Some detais...
Can you share the link to where you have bought this or do you have a link to the probe?
