  3. Command For Disconnecting Connection With GXDLMSXMLClient
Command for disconnecting connection with GXDLMSXMLClient
By pramodahanya , 28 October, 2020
Dear,
What is the command for manually disconnecting the connection while using the GXDLMSXMLClient? I have tried the <DisconnectRequest /> like how it was in the GXDLMSDirector but I get an error saying "invalid command".
Best Regards
Pramod
6 years ago
Dear Pramod,
Dear Pramod,
If you are using WRAPPER you should call release.
pramodahanya
6 years ago
Thank you Mikko, Should I use
Thank you Mikko, Should I use <Release /> in the XML messages. Is this different for HDLC or the same would work with HDLC?
BR
Pramod
6 years ago
Java Xml client doesn't support DisconnectRequest. It's now added. Get the latest version from GitHub. A new version is released next month until that you need to use the GitHub version.
