  3. I Need Connect DTZ27 To Gurux ?
i need connect DTZ27 to Gurux ?
By enhee88009932 , 22 October, 2020
Gurux.Serial
enhee88009932
6 years ago
Image 2
Image 2
enhee88009932
6 years ago
Error image
Error image
6 years ago
The reason is usually in cables or baud rate. Check both and try with different baud rates.
enhee88009932
6 years ago
I check cable and baud rates
I check cable and baud rates . all correct.
Star MMS use read data. but i need gurux ? not connect
6 years ago
I notest that your serial port is different. Do you try to read data using an optical probe? If you, change the start protocol from DLMS to IEC.
enhee88009932
6 years ago
i using optical probe. and
i using optical probe. and error same " Failed to receive reply from the device in given time "
6 years ago
Select "View" | "Log" and "View Log". Is the meter returning anything?
enhee88009932
6 years ago
System.Exception: Invalid
System.Exception: Invalid host name.
at GXDLMSDirector.DevicePropertiesForm.UpdateSettings(GXDLMSMeter device, Boolean validate)
at GXDLMSDirector.DevicePropertiesForm.OKBtn_Click(Object sender, EventArgs e)
03:32:18 Initializing serial connection.
3:32:19 AM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
03:32:24 Data send failed. Try to resend 1/3
03:32:29 Data send failed. Try to resend 2/3
3:32:34 AM Failed to receive reply from the device in given time.
03:32:34 Disconnect request
3:32:34 AM Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
03:32:39 Data send failed. Try to resend 1/3
03:32:44 Data send failed. Try to resend 2/3
3:32:49 AM Failed to receive reply from the device in given time.
03:32:53 Initializing serial connection.
3:32:54 AM Send SNRM request.
03:32:59 Data send failed. Try to resend 1/3
03:33:04 Data send failed. Try to resend 2/3
3:33:09 AM Failed to receive reply from the device in given time.
03:33:09 Disconnect request
3:33:09 AM Send Disconnect request.
03:33:14 Data send failed. Try to resend 1/3
03:33:19 Data send failed. Try to resend 2/3
3:33:24 AM Failed to receive reply from the device in given time.
System.Exception: Invalid name.
System.Exception: Invalid serial port.
01:57:30 Initializing serial connection.
1:57:31 AM Send SNRM request.
7E A0 07 2B 21 93 F6 C4 7E
01:57:36 Data send failed. Try to resend 1/3
01:57:41 Data send failed. Try to resend 2/3
1:57:46 AM Failed to receive reply from the device in given time.
01:57:46 Disconnect request
1:57:46 AM Send Disconnect request.
7E A0 07 2B 21 53 FA 02 7E
01:57:51 Data send failed. Try to resend 1/3
01:57:56 Data send failed. Try to resend 2/3
1:58:01 AM Failed to receive reply from the device in given time.
02:25:04 Initializing serial connection.
2:25:05 AM Send SNRM request.
02:25:10 Data send failed. Try to resend 1/3
02:25:15 Data send failed. Try to resend 2/3
2:25:20 AM Failed to receive reply from the device in given time.
02:25:20 Disconnect request
2:25:20 AM Send Disconnect request.
02:25:25 Data send failed. Try to resend 1/3
02:25:30 Data send failed. Try to resend 2/3
2:25:35 AM Failed to receive reply from the device in given time.
02:27:03 Initializing serial connection.
2:27:04 AM Send SNRM request.
02:27:09 Data send failed. Try to resend 1/3
02:27:14 Data send failed. Try to resend 2/3
2:27:19 AM Failed to receive reply from the device in given time.
02:27:19 Disconnect request
2:27:19 AM Send Disconnect request.
02:27:24 Data send failed. Try to resend 1/3
02:27:29 Data send failed. Try to resend 2/3
2:27:34 AM Failed to receive reply from the device in given time.
02:29:55 Initializing serial connection.
System.UnauthorizedAccessException: Access to the port 'COM4' is denied.
02:34:23 Initializing serial connection.
02:34:33 Initializing serial connection.
2:34:34 AM Send SNRM request.
02:34:39 Data send failed. Try to resend 1/3
02:34:44 Data send failed. Try to resend 2/3
2:34:49 AM Failed to receive reply from the device in given time.
02:34:49 Disconnect request
2:34:49 AM Send Disconnect request.
02:34:54 Data send failed. Try to resend 1/3
02:34:59 Data send failed. Try to resend 2/3
2:35:04 AM Failed to receive reply from the device in given time.
02:36:31 Initializing serial connection.
2:36:33 AM Send SNRM request.
7E A0 08 02 2B 21 93 7F A2 7E
02:36:38 Data send failed. Try to resend 1/3
02:36:43 Data send failed. Try to resend 2/3
2:36:48 AM Failed to receive reply from the device in given time.
02:36:48 Disconnect request
2:36:48 AM Send Disconnect request.
7E A0 08 02 2B 21 53 73 64 7E
02:36:53 Data send failed. Try to resend 1/3
02:36:58 Data send failed. Try to resend 2/3
2:37:03 AM Failed to receive reply from the device in given time.
System.NullReferenceException: Object reference not set to an instance of an object.
11:22:31 Initializing serial connection.
11:22:32 AM Send SNRM request.
7E A0 07 2D 03 93 AC 02 7E
11:22:37 Data send failed. Try to resend 1/3
11:22:42 Data send failed. Try to resend 2/3
11:22:47 AM Failed to receive reply from the device in given time.
11:22:47 Disconnect request
11:22:47 AM Send Disconnect request.
7E A0 07 2D 03 53 A0 C4 7E
11:22:52 Data send failed. Try to resend 1/3
11:22:57 Data send failed. Try to resend 2/3
11:23:02 AM Failed to receive reply from the device in given time.
11:23:33 Initializing serial connection.
11:23:34 AM Send SNRM request.
7E A0 07 21 03 93 0F A7 7E
11:23:39 Data send failed. Try to resend 1/3
11:23:44 Data send failed. Try to resend 2/3
11:23:49 AM Failed to receive reply from the device in given time.
11:23:49 Disconnect request
11:23:49 AM Send Disconnect request.
7E A0 07 21 03 53 03 61 7E
11:23:54 Data send failed. Try to resend 1/3
11:23:59 Data send failed. Try to resend 2/3
11:24:04 AM Failed to receive reply from the device in given time.
11:26:39 Initializing serial connection.
11:26:41 AM Send SNRM request.
11:26:46 Data send failed. Try to resend 1/3
11:26:51 Data send failed. Try to resend 2/3
11:26:56 AM Failed to receive reply from the device in given time.
11:26:56 Disconnect request
11:26:56 AM Send Disconnect request.
11:27:01 Data send failed. Try to resend 1/3
11:27:06 Data send failed. Try to resend 2/3
11:27:11 AM Failed to receive reply from the device in given time.
11:42:06 Initializing serial connection.
11:42:08 AM Send SNRM request.
11:42:13 Data send failed. Try to resend 1/3
11:42:18 Data send failed. Try to resend 2/3
11:42:23 AM Failed to receive reply from the device in given time.
11:42:23 Disconnect request
11:42:23 AM Send Disconnect request.
11:42:28 Data send failed. Try to resend 1/3
11:42:33 Data send failed. Try to resend 2/3
11:42:38 AM Failed to receive reply from the device in given time.
13:00:15 Initializing serial connection.
13:01:15 Initializing serial connection.
13:06:05 Initializing serial connection.
13:33:26 Initializing serial connection.
13:33:54 Initializing serial connection.
1:33:55 PM Send SNRM request.
13:34:01 Data send failed. Try to resend 1/3
13:34:06 Data send failed. Try to resend 2/3
1:34:11 PM Failed to receive reply from the device in given time.
13:34:11 Disconnect request
1:34:11 PM Send Disconnect request.
13:34:16 Data send failed. Try to resend 1/3
13:34:21 Data send failed. Try to resend 2/3
1:34:26 PM Failed to receive reply from the device in given time.
13:40:14 Initializing serial connection.
13:40:15 IEC Sending:/?!<CR><LF>
13:40:25 Failed to receive reply from the device in given time.
13:41:14 Initializing serial connection.
13:41:15 IEC Sending:/?!<CR><LF>
13:41:25 Failed to receive reply from the device in given time.
13:42:09 Initializing serial connection.
13:42:10 IEC Sending:/?!<CR><LF>
13:42:20 Failed to receive reply from the device in given time.
13:42:36 Initializing serial connection.
13:42:37 IEC Sending:/?!<CR><LF>
13:42:47 Failed to receive reply from the device in given time.
13:44:53 Initializing serial connection.
1:44:55 PM Send SNRM request.
7E A0 07 2D 2D 93 8F BB 7E
13:45:00 Data send failed. Try to resend 1/3
13:45:05 Data send failed. Try to resend 2/3
1:45:10 PM Failed to receive reply from the device in given time.
13:45:10 Disconnect request
1:45:10 PM Send Disconnect request.
7E A0 07 2D 2D 53 83 7D 7E
13:45:15 Data send failed. Try to resend 1/3
13:45:20 Data send failed. Try to resend 2/3
1:45:25 PM Failed to receive reply from the device in given time.
13:45:16 Initializing serial connection.
13:45:17 IEC Sending:/?!<CR><LF>
13:45:27 Failed to receive reply from the device in given time.
13:47:57 Initializing serial connection.
13:47:59 IEC Sending:/?!<CR><LF>
13:48:09 Failed to receive reply from the device in given time.
16:33:27 Initializing serial connection.
16:33:28 IEC Sending:/?!<CR><LF>
16:33:38 Failed to receive reply from the device in given time.
16:40:47 Initializing serial connection.
4:40:48 PM Send SNRM request.
7E A0 07 21 21 93 8C B7 7E
16:40:53 Data send failed. Try to resend 1/3
16:40:58 Data send failed. Try to resend 2/3
4:41:03 PM Failed to receive reply from the device in given time.
16:41:03 Disconnect request
4:41:03 PM Send Disconnect request.
7E A0 07 21 21 53 80 71 7E
16:41:08 Data send failed. Try to resend 1/3
16:41:13 Data send failed. Try to resend 2/3
4:41:18 PM Failed to receive reply from the device in given time.
16:42:11 Initializing serial connection.
4:42:12 PM Send SNRM request.
16:42:17 Data send failed. Try to resend 1/3
16:42:22 Data send failed. Try to resend 2/3
4:42:27 PM Failed to receive reply from the device in given time.
16:42:27 Disconnect request
4:42:27 PM Send Disconnect request.
16:42:32 Data send failed. Try to resend 1/3
16:42:37 Data send failed. Try to resend 2/3
4:42:42 PM Failed to receive reply from the device in given time.
16:43:59 Initializing serial connection.
4:44:00 PM Send SNRM request.
16:44:05 Data send failed. Try to resend 1/3
16:44:10 Data send failed. Try to resend 2/3
4:44:15 PM Failed to receive reply from the device in given time.
16:44:15 Disconnect request
4:44:15 PM Send Disconnect request.
16:44:20 Data send failed. Try to resend 1/3
16:44:25 Data send failed. Try to resend 2/3
4:44:30 PM Failed to receive reply from the device in given time.
16:46:58 Initializing serial connection.
4:46:59 PM Send SNRM request.
16:47:04 Data send failed. Try to resend 1/3
16:47:09 Data send failed. Try to resend 2/3
4:47:14 PM Failed to receive reply from the device in given time.
16:47:14 Disconnect request
4:47:14 PM Send Disconnect request.
16:47:19 Data send failed. Try to resend 1/3
16:47:24 Data send failed. Try to resend 2/3
4:47:29 PM Failed to receive reply from the device in given time.
09:44:15 Initializing serial connection.
9:44:17 AM Send SNRM request.
09:44:22 Data send failed. Try to resend 1/3
09:44:27 Data send failed. Try to resend 2/3
9:44:32 AM Failed to receive reply from the device in given time.
09:44:32 Disconnect request
9:44:32 AM Send Disconnect request.
09:44:37 Data send failed. Try to resend 1/3
09:44:42 Data send failed. Try to resend 2/3
9:44:47 AM Failed to receive reply from the device in given time.
09:47:52 Initializing serial connection.
09:47:53 IEC Sending:/?!<CR><LF>
09:48:03 Failed to receive reply from the device in given time.
09:52:22 Initializing serial connection.
9:52:24 AM Send SNRM request.
09:52:29 Data send failed. Try to resend 1/3
09:52:34 Data send failed. Try to resend 2/3
9:52:39 AM Failed to receive reply from the device in given time.
09:52:39 Disconnect request
9:52:39 AM Send Disconnect request.
09:52:44 Data send failed. Try to resend 1/3
09:52:49 Data send failed. Try to resend 2/3
9:52:54 AM Failed to receive reply from the device in given time.
11:57:13 Initializing serial connection.
11:57:14 AM Send SNRM request.
11:57:19 Data send failed. Try to resend 1/3
11:57:24 Data send failed. Try to resend 2/3
11:57:29 AM Failed to receive reply from the device in given time.
11:57:29 Disconnect request
11:57:29 AM Send Disconnect request.
11:57:34 Data send failed. Try to resend 1/3
11:57:39 Data send failed. Try to resend 2/3
11:57:44 AM Failed to receive reply from the device in given time.
13:22:32 Initializing serial connection.
1:22:33 PM Send SNRM request.
13:22:38 Data send failed. Try to resend 1/3
13:22:43 Data send failed. Try to resend 2/3
1:22:48 PM Failed to receive reply from the device in given time.
13:22:48 Disconnect request
1:22:48 PM Send Disconnect request.
13:22:53 Data send failed. Try to resend 1/3
13:22:58 Data send failed. Try to resend 2/3
1:23:03 PM Failed to receive reply from the device in given time.
System.ArgumentException: The PortName cannot be empty.
Parameter name: PortName
at System.IO.Ports.SerialPort.set_PortName(String value)
at Gurux.Serial.GXSerial.set_PortName(String value)
at GXDLMSDirector.DevicePropertiesForm.AdvancedBtn_Click(Object sender, EventArgs e)
13:37:08 Initializing serial connection.
1:37:09 PM Send SNRM request.
13:37:14 Data send failed. Try to resend 1/3
13:37:19 Data send failed. Try to resend 2/3
1:37:24 PM Failed to receive reply from the device in given time.
13:37:24 Disconnect request
1:37:24 PM Send Disconnect request.
13:37:29 Data send failed. Try to resend 1/3
13:37:34 Data send failed. Try to resend 2/3
1:37:39 PM Failed to receive reply from the device in given time.
13:58:01 Initializing serial connection.
13:58:03 IEC Sending:/?!<CR><LF>
13:58:13 Failed to receive reply from the device in given time.
14:15:38 Initializing serial connection.
14:15:39 IEC Sending:/?!<CR><LF>
14:15:49 Failed to receive reply from the device in given time.
System.UriFormatException: Invalid URI: The format of the URI could not be determined.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at Gurux.DLMS.AMI.UI.GXDlmsAmi.GetServerAddress(String address)
at Gurux.DLMS.AMI.UI.GXDlmsAmi.GetDevices(String name, TargetType targets)
at Gurux.DLMS.AMI.UI.GXDlmsAmi.Gurux.DLMS.IGXDataConcentrator.GetDevices(String name)
at GXDLMSDirector.MainForm.LoadFile(String path)
at GXDLMSDirector.MainForm.OnGetDevices(String path)
at Gurux.DLMS.AMI.UI.GXDlmsAmi.GetDeviceTemplates(String name, TargetType targets)
at Gurux.DLMS.AMI.UI.GXDlmsAmi.AddDevice(IWin32Window owner)
at GXDLMSDirector.MainForm.AddDevice(GXDLMSDevice dev)
at GXDLMSDirector.MainForm.AddDeviceMnu_Click(Object sender, EventArgs e)
6 years ago
The meter should answer to /?!<CR><LF>. You need to check the baud rate.
The default baud rate is 300, but I believe that your meter is using something else. Can you read IEC Local port Setup object. 0.0.20.0.0.255? It should show the default baud rate.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
