  3. Time of Reading Date Format
time of reading date format
By kapil , 7 October, 2020
Gurux DLMS for Android
Hi ,
When I am reading the clock object in some meter I am getting the MM-DD-YY(07-10-20) format and in some meter DD-MM-YY (10-07-20).
6 years ago
Are you using the Android version to read it? Date-time is format using environment settings. It's coming in the same format always from the meter.
kapil
6 years ago
yes I am using android
yes I am using android version . mobile phone date time is on DD- MM-YY. In some meters this problem occurs
6 years ago
Are you sure that the date-time is correct on the meter? Can you check that from the meter?
kapil
6 years ago
Hi ,
Hi ,
Yes, It is depends on the android system environment.
Thanks for your reply,
6 years ago
I'm glad that this is solved. The new version from DLMS Android was released yesterday where are a lot of new features.
kapil
6 years ago
Thanks sir
Thanks sir
  • sachdev.ankit
  • Josej2r
  • pradip
  • Fayaz Shaik
  • hezhangnihao@163.com
