  3. Connection Is Permanently Rejected No Reason Is Given
Connection is permanently rejected No reason is given
By Remith , 30 September, 2020
Hi, I am getting "Connection is permanently rejected. No reason is given." while authenticating after upgrading the firmware. Old firmware meter still working without any issues.
Firmware update done through GXDLMSDirector and through GXDLMSDirector still I am able to read/operate the meter. But Java application giving this error. Given the Logs below.
Authentication: None
ClientAddress: 0x10
<- 30-09-2020 15:33:46.392 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
-> 30-09-2020 15:33:47.929 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 04 34 00 07
<- 30-09-2020 15:33:47.930 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 02 FF 02 00
-> 30-09-2020 15:33:48.691 00 01 00 01 00 10 00 09 C4 01 C1 00 06 00 00 29 CD
FRAME COUNTER 10701
Authentication: Low
ClientAddress: 0x20
<- 30-09-2020 15:33:48.692 00 01 00 20 00 01 00 68 60 66 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 34 04 32 21 30 30 00 00 29 CD 0E 3E 83 9B B2 A2 BA CB D7 3F E0 34 7B CB D5 D7 43 B3 0C 63 73 7C 64 82 FD 0B BE BF 72 14 C0 F0 D2 39 56 80 AE D0 92 5F ED CD 8E
-> 30-09-2020 15:33:49.833 00 01 00 01 00 20 00 21 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00
gurux.dlms.GXDLMSException: Connection is permanently rejected
No reason is given.
at gurux.dlms.GXAPDU.parsePDU2(GXAPDU.java:1168)
at gurux.dlms.GXAPDU.parsePDU(GXAPDU.java:901)
at gurux.dlms.GXDLMSClient.parseAareResponse(GXDLMSClient.java:822)
Kindly help me to resolve this issue.
6 years 1 month ago
The invocation counter is not increased. You are reading it, but not increase by one. You should do it like this:
https://github.com/Gurux/gurux.dlms.java/blob/f3fe3ef49d40ce366a5f33c04…
Remith
6 years 1 month ago
Great !!!!!!!!
Great !!!!!!!!
This logic worked for me.
Thank you very much.
  • Raja Golf - Kantor Pusat | WA 083148835648
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
