  3. ProfileGeneric Capture Objects Read Error
ProfileGeneric capture objects read error
By MNN , 3 September, 2020
Gurux.DLMS.AMI
Hello.
I try to read 0.1.99.98.4.255 and an error occurred:
fail: Gurux.DLMS.AMI.Reader.ReaderService[0]
Failed to Read 0.1.99.98.4.255:2. Capture objects not read.
6 years 2 months ago
There might be a lot of reasons why it fails. Can you read it with GXDLMSDirector?
MNN
Hello.
Hello.
In the GXDLMSDirector, the profileGeneric were considered successfully. But when you read it again, the error is again
We can't repeat this. Have you modified the source code?
MNN
Hello.
Hello.
I downloaded the latest version of AMI. In the director, I added a device, then added it as a template in AMI. Read object 0.0.98.1.1.255, then another object, then 0.0.98.1.1.255 again. An error has occurred.
The first time the object is read, the second time - an error. This happens with all profile generic objects.
Database - sqlite.
MNN
Hello.
Hello.
In the assembly of the end of july, reading worked without errors. Early August build - errors reading attribute 2.
6 years 1 month ago
I'm sorry for the slow reply. Our clients were keeping us busy. I'll ask to check this and get back to this ASAP.
6 years 1 month ago
I'm sorry. I forget to tell you that this is fixed. Get the latest version.
MNN
6 years 1 month ago
Thank you!
Thank you!
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
