  3. Problem of Compilation of ARDUINO IDE
Problem of compilation of ARDUINO IDE
Profile picture for user Cody_M
By Cody_M , 24 June, 2020
Known problems
I"ve tryed to compily with SERVER.INO it was succesed, but the CLIENT.INO is not compilating...:
Related problems
(exit status 1
'mes_init' was not declared in this scope) this is pasted part of an error from ARDUINO.IDE
How can I fix a problem? If you have advice or decision of this problem... you're welcome.
6 years 4 months ago
open gxignore.h and comment DLMS_IGNORE_MALLOC. There are two defines so comment both.
un-comment also this line:
#define DLMS_IGNORE_MALLOC
Because Arduino IDE can't handle defines we must use the file.
We'll try to find a way how to handle client and server without modifying the gxignore.h file.
Cody_M
I did everything according to
I did everything according to your instructions, but I didn't get rid of the error. Tell me please, where have I made a mistake? and thanks for the quick reply
Don't update images. They are compressed and others can't read them.
Un-comment this:
Cody_M
// Gurux Ltd
// Filename: $HeadURL$
// Version: $Revision$,
// $Date$
// $Author$
// Copyright (c) Gurux Ltd
// DESCRIPTION
// This file is a part of Gurux Device Framework.
// Gurux Device Framework is Open Source software; you can redistribute it
// and/or modify it under the terms of the GNU General Public License
// as published by the Free Software Foundation; version 2 of the License.
// Gurux Device Framework is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
// See the GNU General Public License for more details.
// This code is licensed under the GNU General Public License v2.
// Full text may be retrieved at http://www.gnu.org/licenses/gpl-2.0.txt
#ifndef GXIGNORE_H
#define GXIGNORE_H
#ifdef __cplusplus
extern "C" {
#endif
/* Uncomment defines to ignore non-needed parts to make image size smaller. */
// #define DLMS_IGNORE_WRAPPER
// #define DLMS_IGNORE_NOTIFY
// #define DLMS_IGNORE_SERVER
// #define DLMS_IGNORE_CLIENT
// #define GX_DLMS_MICROCONTROLLER
// #define DLMS_IGNORE_HIGH_SHA256
// #define DLMS_IGNORE_HIGH_SHA1
// #define DLMS_IGNORE_HIGH_MD5
// #define DLMS_IGNORE_AES
// #define DLMS_IGNORE_HIGH_GMAC
// #define DLMS_IGNORE_DATA
// #define DLMS_IGNORE_REGISTER
// #define DLMS_IGNORE_EXTENDED_REGISTER
// #define DLMS_IGNORE_DEMAND_REGISTER
// #define DLMS_IGNORE_REGISTER_ACTIVATION
// #define DLMS_IGNORE_PROFILE_GENERIC
// #define DLMS_IGNORE_CLOCK
// #define DLMS_IGNORE_SCRIPT_TABLE
// #define DLMS_IGNORE_SCHEDULE
// #define DLMS_IGNORE_SPECIAL_DAYS_TABLE
// #define DLMS_IGNORE_ASSOCIATION_SHORT_NAME
// #define DLMS_IGNORE_ASSOCIATION_LOGICAL_NAME
// #define DLMS_IGNORE_SAP_ASSIGNMENT
// #define DLMS_IGNORE_IMAGE_TRANSFER
// #define DLMS_IGNORE_IEC_LOCAL_PORT_SETUP
// #define DLMS_IGNORE_ACTIVITY_CALENDAR
// #define DLMS_IGNORE_REGISTER_MONITOR
// #define DLMS_IGNORE_ACTION_SCHEDULE
// #define DLMS_IGNORE_IEC_HDLC_SETUP
// #define DLMS_IGNORE_IEC_TWISTED_PAIR_SETUP
// #define DLMS_IGNORE_MBUS_SLAVE_PORT_SETUP
// #define DLMS_IGNORE_UTILITY_TABLES
// #define DLMS_IGNORE_MODEM_CONFIGURATION
// #define DLMS_IGNORE_AUTO_ANSWER
// #define DLMS_IGNORE_AUTO_CONNECT
// #define DLMS_IGNORE_TCP_UDP_SETUP
// #define DLMS_IGNORE_IP4_SETUP
// #define DLMS_IGNORE_MAC_ADDRESS_SETUP
// #define DLMS_IGNORE_PPP_SETUP
// #define DLMS_IGNORE_GPRS_SETUP
// #define DLMS_IGNORE_SMTP_SETUP
// #define DLMS_IGNORE_GSM_DIAGNOSTIC
// #define DLMS_IGNORE_REGISTER_TABLE
// #define DLMS_IGNORE_STATUS_MAPPING
// #define DLMS_IGNORE_SECURITY_SETUP
// #define DLMS_IGNORE_DISCONNECT_CONTROL
// #define DLMS_IGNORE_LIMITER
// #define DLMS_IGNORE_MBUS_CLIENT
// #define DLMS_IGNORE_PUSH_SETUP
//#define DLMS_IGNORE_MESSAGE_HANDLER
// #define DLMS_IGNORE_PARAMETER_MONITOR
// #define DLMS_IGNORE_WIRELESS_MODE_Q_CHANNEL
// #define DLMS_IGNORE_MBUS_MASTER_PORT_SETUP
// #define DLMS_IGNORE_ZIG_BEE_SAS_STARTUP
// #define DLMS_IGNORE_ZIG_BEE_SAS_JOIN
// #define DLMS_IGNORE_ZIG_BEE_SAS_APS_FRAGMENTATION
// #define DLMS_IGNORE_ZIG_BEE_NETWORK_CONTROL
// #define DLMS_IGNORE_DATA_PROTECTION
// #define DLMS_IGNORE_ACCOUNT
// #define DLMS_IGNORE_CREDIT
// #define DLMS_IGNORE_CHARGE
// #define DLMS_IGNORE_TOKEN_GATEWAY
// #define DLMS_IGNORE_COMPACT_DATA
// #define DLMS_ITALIAN_STANDARD
// #define DLMS_IGNORE_LLC_SSCS_SETUP
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_PHYSICAL_LAYER_COUNTERS
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_MAC_SETUP
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_MAC_FUNCTIONAL_PARAMETERS
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_MAC_COUNTERS
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_MAC_NETWORK_ADMINISTRATION_DATA
// #define DLMS_IGNORE_PRIME_NB_OFDM_PLC_APPLICATIONS_IDENTIFICATION
#define DLMS_USE_CUSTOM_MALLOC
// #define DLMS_IGNORE_OBJECT_POINTERS
// #define DLMS_IGNORE_FLOAT32
// #define DLMS_IGNORE_FLOAT64
//Use EPOCH time. This can be used to improve memory usage.
// #define DLMS_USE_EPOCH_TIME
//Use UTC time zone. Read more: https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
// #define DLMS_USE_UTC_TIME_ZONE
// #define DLMS_IGNORE_SET
//Framework send debug information that can be used in debugging.
// #define DLMS_DEBUG
//Defined if AVR is used.
// #define USE_AVR
//Defined if program memory (flash) is used instead of SRAM.
// #define USE_PROGMEM
#ifdef ARDUINO_ARCH_AVR
//If Arduino is used.
#define USE_PROGMEM
#endif //ARDUINO_ARCH_AVR
#ifdef __cplusplus
#endif
#endif //GXIGNORE_H
Cody_M
Please check, did I do
Please check, did I do everything right?
I still have a compilation problem
Sorry. My mistake. Un-comment this:
Server side functionality is not needed.
Comment this:
Comment DLMS_USE_CUSTOM_MALLOC and DLMS_IGNORE_MALLOC.
Server doesn't use malloc, but the client needs it.
Cody_M
Thank you very much, the
Thank you very much, the compilation was successful
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
