  3. SpecialDaysTable - Try To Add Row - Error
SpecialDaysTable - try to add row - error
By MNN , 18 June, 2020
Gurux.DLMS.AMI
When trying to add a row an error occurs ("The input string was in the wrong format" and "failed to cast object type Gurux.DLMS.GXDLMSMeter to type Gurux.DLMS.AMI.Message.DB.GXDevice"):
System.FormatException: Входная строка имела неверный формат.
в System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
в System.Number.ParseUInt32(String value, NumberStyles options, NumberFormatInfo numfmt)
в System.UInt16.Parse(String s, NumberStyles style, NumberFormatInfo info)
в System.String.System.IConvertible.ToUInt16(IFormatProvider provider)
в Gurux.DLMS.GXDLMSClient.Method(Object name, ObjectType objectType, Int32 index, Object value, DataType type)
в Gurux.DLMS.GXDLMSClient.Method(GXDLMSObject item, Int32 index, Object data)
в Gurux.DLMS.Objects.GXDLMSSpecialDaysTable.Delete(GXDLMSClient client, GXDLMSSpecialDay entry)
в Gurux.DLMS.UI.GXDLMSSpecialDaysTableView.OnSpecialDaysDlg(GXActionArgs arg, GXDLMSSpecialDaysTableDlg dlg, GXDLMSSpecialDay it) в C:\vsts-agent\_work\4\s\development\GXDLMSSpecialDaysTableView.cs:строка 126
6 years 5 months ago
We'll check this tomorrow.
This is fixed and tests are on progress. New version is released today.
This is fixed. Get the latest version.
MNN
Hi, Thank you!
Thank you!
