  3. Image Transfer Resume
Image transfer resume
By sakshi , 5 June, 2020
I want to know can we resume image transfer after connection failure with dlms for java. I have to sent 2000 block. But after 1000 connection get lost due to ping discontinuity. So i want to connect meter again and image data should be transfer from 10001. Could it be possible?
6 years 1 month ago
I can say that it depends on the meter, but usually, it's possible. You can try to read attribute #4 image first not transferred block number and start sending blocks from that. Or you can read attribute #3 and send missing blocks. It's a bit-string that tells what blocks meter has received.
sakshi
6 years 1 month ago
Step 3: Transfers ImageBlocks
Step 3: Transfers ImageBlocks.
int[] imageBlockCount = new int[1];
imageBlockCount[0] = (int) (imgData.length / img.getImageBlockSize());
gxReader.readDataBlock(img.imageBlockTransfer(dlms, imgData, imageBlockCount), reply);
Can you tell me how can we pass block number from where i have to initiate?
Above code always try to send block from 1;
sakshi
6 years 1 month ago
Thanks... i got it how to do.
sakshi
6 years 1 month ago
hi
hi
Now i want to know can we set block number in data. Because it always start block number from 0 in image data when resume.
is it needed to call imageTransferInitiate method while resuming.
thanks
6 years 1 month ago
Because there might be several missing blocks there is no method for this.
You can do it like this:
List<byte[]> packets = new List<byte[]>();
GXDLMSImageTransfer img = new GXDLMSImageTransfer();
byte[][] blocks = img.GetImageBlocks(image);
//Remove blocks that meter has received.
//Generate messages.
foreach (byte[] it in blocks)
packets.AddRange(client.Method(img, 2, it, DataType.Array));
//Send data.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
  • annoyingconsultants
