  3. Bluetooth Integration With Android
Bluetooth Integration with Android
By mshawky , 22 April, 2020
Gurux DLMS for Android
Hello I saw the video of connecting rasperry pi to dlms through bluetooth but I can't find any way to find the Serial Port after connecting to the DLMS Probe. How can I achieve that?
6 years 7 months ago
I believe that you have read this?
http://www.gurux.fi/bluetooth
If you run hcitool can you see your Bluetooth device?
Have you connected your Bluetooth device to serial port using rfcomm?
mshawky
Yes I have read this
I am not using hcitool.. I connected to my bluetooth device using serial port profile with UUID 00001101-0000-1000-8000-00805F9B34FB and now it is connected but I can't find any com port to connect like the example mentioned
For some reason, I didn’t realize you were using Android. Check this:
It uses Gurux serial port for Android:
https://github.com/Gurux/gurux.serial.android
mshawky
I did check the gurux dlms android code it is using gurux serial port through usb host It has no code related to bluetooth connection
I actually have two problems
1. What is the use of the Media Interface and what is the use of getSynchronous() function
2. The steps in GXDLMS client are vague I really cannot go through the steps
and Thanks in advance
I'm sorry. Too many questions at the same time. You can't use Android serial port with Bluetooth.
You can use what communication channel to send data. getSynchronous is used to indicate that the received data is reply. If it's not received data is sent through OnReceived-method.
If you know what you want to read from the meter you don't need to read the association view. Until that you need to call all the functions. DLMS is not an easy protocol and you need to establish the connection as implemented client example. You can save the association view and you don't need to read al the data if you don't want to.
mshawky
6 years 6 months ago
Thanks for your answers
I know the questions are too many but I have been stuck for many days regarding this
So the only way I can use Bluetooth with GXDLMS client is to implement my own GXDLMS client after bluetooth connection right?
do I have to implement IGXMedia in case of using Bluetooth?
If not what are the steps because in the Android DLMS Client there are lots of code which is very confusing for me
You don't need to do anything for GXDLMSClient. It just generates and parses the bytes. You need to send generated bytes using Bluetooth connection to the meter. When you receive data from the meter you give it to the GXDLMSClient using GetData -method.
itcoder
5 years 11 months ago
In reply to Thanks for your answers by mshawky
Hi mshawky. I am now trying
Hi mshawky. I am now trying to use Bluetooth with Gurux on a Xamarin Forms C# application. Did you make any progress with this? I am also unsure if I need to implement IGXMedia for Bluetooth, thanks!
In reply to Hi mshawky. I am now trying by itcoder
You need to implement your own media for Bluetooth. We are planning to add support for Bluetooth at some point. The easiest way to go is if you use GXSerial as a template and modify it for your needs.
sandeep007
5 years 9 months ago
Hi mshawky,
Hi mshawky,
Have u implemented the Bluetooth with GXDLMS please let me know and i am facing issue while connecting to BLE module to read & write EnegryMeters.
delanou
2 years 7 months ago
Did you have any update?
Hi, At the moment Bluetooth…
At the moment Bluetooth is implemented for Xamarin, but not Android Studio.
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
