  3. Secure FX 100 Meter Over TCP IP
Secure FX 100 Meter over TCP IP
By sachinar007 , 3 April, 2020
Gurux.Net
I am trying to communication secure fx100 meter using TCP/IP protocol.
meter can be communicate using GXDLMSDirector user interface, But when i tried same meter with Gurux.DLMS.Client.Example.Net then it doesn't work.
it opens media but throw error when it goes to InitializeConnection phase. in trace it gives only first line
TX: 18:32:19 7E A0 07 03 41 93 5A 64 7E
One more thing , when i tried same meter and code with NIU converter ie . modbus converter it simply communicate successfully.
can you provide root cause for the same.
6 years 5 months ago
There are several parameters in DLMS and if one is wrong, the meter doesn't reply. Can you select trace from GXDLMSDirector's "View" menu and post the first line here. I can check the correct parameters for you.
sachinar007
Please find the same.
14:54:16 Initializing Network connection.
14:54:16 Send AARQ request.
00 01 00 20 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
14:54:16
00 01 00 01 00 20 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 00 80 00 07
14:54:16 Parsing AARE reply succeeded.
Change Interface to WRAPPER and client address to 32. Authentication level is Low and password is ABCD0001
Now you should be able to connect.
sachinar007
Hello Mikko,
Hello Mikko,
Thanks a lot. It works for me.
Sachin
