  3. Push Notification Parsing
By Bhaumik , 12 February, 2020
Gurux.Net
Hi Mikko
I am getting the push notification data from the meter and also able to see parsed data in to GXDLMSDirector in Notification window.
In that how we can check that which objects data are received ?
In GXDLMSDirector, we can see parsed value in XML format. Is there anything from which we can understand that which objects data are there in push notification?
Following is the parsed xml
<WRAPPER len="88" >
<TargetAddress Value="1" />
<SourceAddress Value="40" />
<PDU>
<DataNotification>
<LongInvokeIdAndPriority Value="D00006A5" />
<DateTime Value="07E4020C03120802FFFEB600" />
<NotificationBody>
<DataValue>
<Structure Qty="0D" >
<String Value="ABCD0000000" />
<OctetString Value="0000190900FF" />
<OctetString Value="07E4020C03120802FFFEB600" />
<Float32 Value="4362DC29" />
<Float32 Value="3D8F5C29" />
<Float32 Value="443A0000" />
<Float32 Value="41200000" />
<UInt16 Value="0016" />
<UInt32 Value="00000003" />
<Float32 Value="00000000" />
<Boolean Value="true" />
<UInt32 Value="00004380" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
<GeneralGloCiphering>
<SystemTitle Value="41424344450303030" />
<CipheredService Value="300000452101F3864F51BCA61FEC47BD31A2DBE7C69F11B6238A09BFA7AA027C0AC5908CABE502D7DDB07B1B4FE8777FE3DE09FF48C2217A7409F5D47F90FC1ACF0847228C31B589533650D8637AB109753B0716C1A453E7F38E8AD3E3AD98314CB1F06322C4D657D18D4E3D70918E244F45A4B9E4" />
</GeneralGloCiphering>
</PDU>
</WRAPPER>
6 years 8 months ago
Content of Push notifications might be anything. You need to know what meter is sending. On option is to save the Push Object list to the push list. Some meters are sending the logical name of the push object as the first parameter. There is no simple solution for this.
Bhaumik
Is there any specific push notification data format (Smart meter to HES ) defined in Indian Standard 16444 ?
The version from IS 16444 that I have don't define the content of the push messages.
They might be defined on the other IS standards.
Bhaumik
Can you please check in IS15959 and IS15959-2 as well ?
IS15959-2 defines some push messages, for example 0.0.25.9.1.255.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
