  3. Serializing Dlms Object
Serializing Dlms object
By bleg , 19 February, 2019
is there a simple way to serialize dlms object into xml or json (even better)?
7 years 5 months ago
You can save COSEM objects to xml (file or OutputStream) using GXDLMSObjectCollection.save method.
JSON is not supported at the moment.
bleg
Thank you. I’ll try that
pramodahanya
You can use XStream
You can use XStream from ThoughtWorks. You can use it to serialize and deserialize pretty much any Java object to/from XML and JSON.
You can use XStream
That is true. We have made own serializer because we must use same xml for several languages, like java, C#, Python, etc. If you are using xml only java apps, you can use what serializer you want to.
Bhaumik
6 years 6 months ago
In reply to Serializing Dlms object by Kurumi
As you suggested, I saved COSEM object using GXDLMSObjectCollection.save.
Now I am getting following XML.
<Objects>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.0.255</LN>
<Description>Invalid</Description>
<ApplicationContextName>
<JointIsoCtt>2</JointIsoCtt>
<Country>16</Country>
<CountryName>756</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<DlmsVersionNumber>6</DlmsVersionNumber>
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<SecuritySetupReference>0.0.0.0.0.0</SecuritySetupReference>
</GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<DlmsUA>8</DlmsUA>
<XDLMSContextInfo>
</XDLMSContextInfo>
<DlmsUA>8</DlmsUA>
<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
</GXDLMSData>
<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
</GXDLMSClock>
</Objects>
The problem with this XML is, I am not able to deserialize it.
Can you please suggest any solution so that I can deserialize the XML into GXDLMSObjectCollection?
Bhaumik,
Thanks in advance.
In reply to Hi Mikko, by Bhaumik
Hi Bhaumik,
Hi Bhaumik,
  • Rolling-Slots-Bok
  • OskoNadyLoold
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
