  3. Example Code For Write and Action Methods
Example code for Write and Action Methods
By utkarsh , 16 January, 2020
Can you please share example code for write and action methods.
Example for Disconnect control to make Connect from Disconnect.
Utkarsh
6 years 8 months ago
Hi Utkarsh,
Hi Utkarsh,
You can do actions like this:
GXDLMSDisconnectControl d = new GXDLMSDisconnectControl();
readDLMSPacket(d.remoteReconnect(dlms), reply);
Check the client example. There is a write-method that writes wanted object attribute to the meter.
utkarsh
Thanks Mikko. But meter
Thanks Mikko. But meter (server) side implementation will be the same ?
Currently below are the messages
Client Connected.
RX: 00 01 00 30 00 01 00 70 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 E4 A4 FC 17 BA AB 5A 87 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 4E 37 64 78 66 6D 48 78 7A 43 67 32 38 34 72 65 BE 34 04 32 21 30 30 00 00 00 54 99 61 92 95 A4 8A BB 0C 79 AD C5 75 CC 57 7E 4E 78 97 ED C8 68 BC B4 F7 73 83 0A 84 A9 9E 44 FB D3 8C A9 00 CB 60 EB B3 39 E6 97
Jan 20, 2020 2:34:38 AM gurux.dlms.GXDLMSServerBase handleCommand
INFO: AARQ Request
TX: 00 01 00 01 00 30 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 73 71 4B 39 13 43 2F 07 65 62 24 72 77 03 28 24 BE 23 04 21 28 1F 30 00 00 00 00 F0 72 25 65 5B 37 8D 02 B8 69 79 E5 8B FC 6A 1B 2D 19 2F EF 66 AA C2 19 6A CF
RX: 00 01 00 30 00 01 00 32 CB 30 30 00 00 00 55 01 AC 42 B7 91 CB F6 B6 3E 42 67 F5 F5 CD 3A EF 54 0C 8E 24 33 DB 4B 03 7E 2B 8C 8E 2E 47 D6 6B 98 AD 40 19 4E 43 5E 56 B7 C6 9A
INFO: Method Request
TX: 00 01 00 01 00 30 00 2B CF 29 30 00 00 00 00 3F 73 E2 3A 45 33 84 12 12 FC 70 EE 47 DE 08 9E A2 07 02 58 4A 2A DD 29 30 12 D1 F0 9C 2C C2 73 FA C7 7C C8
RX: 00 01 00 30 00 01 00 20 D0 1E 30 00 00 00 56 E2 28 2B 42 40 C7 15 EB 66 24 3E DF 68 A1 7F 39 6A 90 81 5E E9 4E D9 E2 53
INFO: Get Request
Client Read value from 0.0.96.3.10.255 attribute: 4.
TX: 7E A0 07 61 03 97 5D E7 7E
Jan 20, 2020 2:34:58 AM gurux.dlms.GXDLMSServerBase handleCommand
INFO: Get Request
Jan 20, 2020 2:35:18 AM gurux.dlms.GXDLMSServerBase handleCommand
INFO: Get Request
Jan 20, 2020 2:35:38 AM gurux.dlms.GXDLMSServerBase handleCommand
INFO: Get Request
RX: 00 01 00 30 00 01 00 3B 62 39 80 01 00 BE 34 04 32 21 30 30 00 00 00 54 99 61 92 95 A4 8A BB 0C 79 AD C5 75 CC 57 7E 4E 78 97 ED C8 68 BC B4 F7 73 83 0A 84 A9 9E 44 FB D3 8C A9 00 CB 60 EB B3 39 E6 97
Jan 20, 2020 2:35:58 AM gurux.dlms.GXDLMSServerBase handleCommand
INFO: RELEASE Request
TX: 00 01 00 01 00 30 00 2A 63 24 80 01 00 BE 22 04 21 28 1F 30 00 00 00 01 4F B0 2C B4 68 C1 70 10 B8 6D AB 24 32 09 D3 C9 86 DE D2 30 BD 21 A9 98 23 04
Client Disconnected.
Utkarsh
Hi Utkarsh,
Hi Utkarsh,
You need to save values on the server side or if you are using disconnect control you need to get postAction and them disconnect the meter.
Check this:
https://www.gurux.fi/Gurux.DLMS.Server
utkarsh
I don't want to save the values but just reply to HES successful SET or ACTION response.
As per README document, we can have own write/action implementation or it will be handled by framework. So I haven't changed write/action methods.
But getting exception while performing SET for ActivityCalendar.
In below code value is always NULL for ActivityCalendar object and get HARDWARE_FAULT exception.
private static void handleSetRequestNormal(final GXDLMSSettings settings,
final GXDLMSServerBase server, final GXByteBuffer data,
final int type, final GXDLMSLNParameters p,
final GXByteBuffer replyData, final GXDLMSTranslatorStructure xml)
throws Exception {
Object value = null;
if (value instanceof byte[]) {
DataType dt = obj.getDataType(index);
if (dt != DataType.NONE
&& dt != DataType.OCTET_STRING) {
value = GXDLMSClient.changeType((byte[]) value, dt);
e.setValue(value);
ValueEventArgs[] list = new ValueEventArgs[] { e };
if (p.isMultipleBlocks()) {
server.setTransaction(new GXDLMSLongTransaction(list,
Command.GET_REQUEST, data));
server.notifyWrite(list);
if (e.getError() != ErrorCode.OK) {
p.setStatus(e.getError().getValue());
} else if (!e.getHandled() && !p.isMultipleBlocks()) {
obj.setValue(settings, e); -> exception raised here.
server.notifyPostWrite(list);
p.setInvokeId(e.getInvokeId());
} catch (Exception ex) {
p.setStatus(ErrorCode.HARDWARE_FAULT.getValue());
Exception is raised from below code in GXDLMSActivityCalendar class
case 6:
tmp = new String((byte[]) e.getValue());
Utkarsh
Hi Utkarsh,
Hi Utkarsh,
We have clients who are using non-ASCII activity calendar names. For this reason, the name is expected to be HEX string as a default. I'll try to find a way how to handle this.
In the meantime, you need to do this in GXDLMSDirector.
Select "Access rights" from "Activity calendar". Then change "Active Calendar Name" UIType from None to String. See pic below. Now you can write names as ASCII string.
Now you can receive data as expected.
