  3. Notifications Are Not Encrypted
Notifications are not encrypted
By utkarsh , 20 January, 2020
I am using push listener example for send notifications to HES. But it seems they are not encrypted.
HES has received
00 3C 0F C0 00 00 01 00 02 02 01 02 02 04 12 00 28 09 06 00 07 19 09 00 FF 0F 02 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E4 01 0D 01 0D 23 01 62 01 2C 00
Utkarsh
6 years 9 months ago
Hi Utkarsh,
Hi Utkarsh,
You need to set security, system title, block cipher key and authentication key if you want to encrypt (cipher) the data.
utkarsh
Thanks Mikko. But
Thanks Mikko. But GXDLMSNotify class doesn't implement security, system title, block cipher key and authentication key.
Do we need to implement GXDLMSClient to send notifications.
Utkarsh
You need to use GXDLMSSecureNotify. GXDLMSClient doesn't send notifications, it can receive them.
utkarsh
We use GXDLMSSecureNotify class but still messages are not encrypted.
media = new GXNet(NetworkType.TCP, getHostName(), getPort(),false,ipv4,getRemoteHostName(),getRemotePort());
//GXDLMSNotify cl = new GXDLMSNotify(true, 64, 1, InterfaceType.WRAPPER);
GXDLMSSecureNotify cl = new GXDLMSSecureNotify(true, 64, 1, InterfaceType.WRAPPER);
GXDLMSPushSetup p = new GXDLMSPushSetup();
GXDLMSClock clock = new GXDLMSClock();
clock.setTime(new GXDateTime(Calendar.getInstance().getTime()));
p.getPushObjectList()
.add(new GXSimpleEntry<GXDLMSObject, GXDLMSCaptureObject>(p,
new GXDLMSCaptureObject(2, 0)));
.add(new GXSimpleEntry<GXDLMSObject, GXDLMSCaptureObject>(clock,
media.open();
for (byte[] it : cl.generatePushSetupMessages(null, p)) {
public GXDLMSSecureNotify(final boolean useLogicalNameReferencing,
final int clientAddress, final int serverAddress,
final InterfaceType interfaceType) {
super(useLogicalNameReferencing, clientAddress, serverAddress,
interfaceType);
ciphering = new GXCiphering("ABCDEFGH".getBytes());
setCipher(ciphering);
public GXCiphering(final byte[] title) {
publicKeys = new ArrayList<Map.Entry<CertificateType, PublicKey>>();
certificates = new ArrayList<GXx509Certificate>();
setSecurity(Security.NONE);
setSystemTitle(title);
setBlockCipherKey("eeslekakgsl06abc".getBytes());
setAuthenticationKey("eeslekakgsl06abc".getBytes());
Same GXCiphering is used for GXDLMSServerLN_47 which is working fine.
Message:
00 3C 0F C0 00 00 01 00 02 02 01 02 02 04 12 00 28 09 06 00 04 19 09 00 FF 0F 02 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E4 01 16 03 0A 0E 05 15 01 E0 00
Utkarsh
Hi Utkarsh,
Hi Utkarsh,
In GXCiphering-method you are setting security to NONE.
Try like this:
GXDLMSSecureNotify cl = new GXDLMSSecureNotify(true, 1, 1, InterfaceType.WRAPPER);
cl.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
utkarsh
Thanks Mikko. It worked.
MaxLe
6 years 7 months ago
Created as new question.
In reply to Hi Mikko, by MaxLe
Hi Max,
Hi Max,
Please, create a new topic if you have a new question. I'll answer for your question there.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
