  3. Why Does GXNet Socket Attribute Become Null After Starting a Thread?
Why does GXNet socket attribute become null after starting a thread?
By SgmUsr , 23 December, 2019
Gurux.Net
I'm following the Gurux.DLMS.Meter.Listener.Net example but when I try to start thread with my personal class method DeviceManager.StartManageDevice() (class builds like GXDLMSReader, with same attribute), the private attribute "socket" of GXNet object becomes null and I can't send and receive data.
private void GXNetSocket_OnReceived(object sender, Gurux.Common.ReceiveEventArgs e)
GXNet server = (GXNet)sender;
try
using (GXNet cs = server.Attach(e.SenderInfo))
DeviceManager dm = new DeviceManager(cs, matricola, sst, frameCounter);
Thread currentThread = new Thread(dm.StartManageDevice);
currentThread.Start();
catch (Exception ex)
Console.WriteLine(ex.Message);
I don't understand why.
6 years 11 months ago
The reason for this is because you attach the GXNew client and it's released after you leave OnReceived.
Try to attach the net media in your thread.
SgmUsr
6 years 10 months ago
now it works.
SgmUsr
about this question, this works correctly with Tcp, but with Udp connections I can't use Attach() method: I only need to pass GXNet object in a thread?
In reply to Hi Mikko, by SgmUsr
In UDP there are no connections. If you know the sender address and port you can send data directly.
SgmUsr
hi,
hi,
but how is it possible GXNet.Send has its attribute 'socket' (being socket a IDisposable type) as UdpClient type? because, if I call back Send method (from GXNet), I'm using GXNet object, not UdpClient object, so the attribute socket will be null.
I cannot understand this thing.
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
  • ASIA GOLF Driving Range Intercon | WA 083148835648
