  3. Cannot Start Server With Ipv6 Address
Cannot start server with ipv6 address
By Varun Sharma , 29 November, 2019
GXNet server = new GXNet();
server.Protocol = NetworkType.Tcp;
server.UseIPv6 = true;
server.HostName = "2402:3a80:1700:486:c089:89e3:b0da:6c5f";
server.Port = 4059;
server.Open();
I am using ipv6 sim
Gxdlmsdirector also not able to read data form meter when using ipv6 hostname address
6 years 12 months ago
You don't give HostName when you start the server. Server is bind to local ip address.
Varun Sharma
6 years 11 months ago
ok My server is getting the
ok My server is getting the push data.
But i am not able to read meter.I am using ipv6 sim with static address.
Gxdlmsdirector is also not able to read data form meter when using ipv6 static address.
what should be the client address and server address when reading in Low mode.
Sometime it shows "invalid connection" and sometime "fail to read reply from meter".
Client and server address depends on the manufacturer.
Invalid connection means that TCP/IP connection failed and "fail to read reply from meter" means that TCP/IP connection succeeded, but the meter didn't reply.
Varun Sharma
I can download my meter
I can download my meter through Gprs with other software like "Kalkitech" and with same client and server address i am using Gxdlmsdirector.
But with Gxdlmsdirector it is not possible.Is there any issue in your software to download using gprs because using serialport it is downloading fine.
We are using GPRS all the time. Can you send a few first trace line from Kalki so I can check that your settings are the same. I believe that your meter uses WRAPPER, but I need to verify it.
Varun Sharma
09 : 59 : 52
09 : 59 : 52 SM_TCP COSEM OUT DATA
09 : 59 : 52 ====>Tx SM_TCP 60 00 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 08
80 06 31 32 33 34 35 36 BE 34 04 32 21 30 30 00 01 5F E6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 3E DC FF 43 10 20 C4 AD 94 6E DB 4F
09 : 59 : 52 SM_TCP COSEM OUT DATA - CIPHERED
09 : 59 : 52 ====>Tx SM_TCP 60 64 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 08
80 06 31 32 33 34 35 36 BE 34 04 32 21 30 30 00 01 5F E6 83 41 73 45 54 BA 77 0D 82 5C 80 11 49 16 5A 7C 7C C8 14 F2 AF
83 FA D7 FA 75 4C 6C 50 64 89 3E DC FF 43 10 20 C4 AD 94 6E DB 4F
09 : 59 : 52 SM_TCP SERVICE = AARQ
09 : 59 : 52 SM_TCP SENDING WRAPPER FRAME
09 : 59 : 52 ====>Tx SM_TCP 00 01 00 20 00 01 00 66 60 64 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60
85 74 05 08 02 01 AC 08 80 06 31 32 33 34 35 36 BE 34 04 32 21 30 30 00 01 5F E6 83 41 73 45 54 BA 77 0D 82 5C 80 11 49
16 5A 7C 7C C8 14 F2 AF 83 FA D7 FA 75 4C 6C 50 64 89 3E DC FF 43 10 20 C4 AD 94 6E DB 4F
09 : 59 : 53 SM_TCP RECEIVED WRAPPER FRAME
09 : 59 : 53 <====Rx SM_TCP 00 01 00 01 00 20 00 4A 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 45 4C 53
30 30 30 31 30 BE 23 04 21 28 1F 30 00 00 00 08 01 AE FD 3A E8 BE 13 C3 D0 5C 03 34 C3 FD F8 31 55 AE 5B 36 D7 84 28 68
2A 26
09 : 59 : 53 SM_TCP RECEIVED APPLICATION LAYER FRAME - CIPHERED
09 : 59 : 53 <====Rx SM_TCP 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 45 4C 53 30 30 30 31 30 BE 23 04
21 28 1F 30 00 00 00 08 08 00 06 5F 1F 04 00 00 10 14 02 00 00 07 F8 31 55 AE 5B 36 D7 84 28 68 2A 26
21 28 1F 30 00 00 00 08 01 AE FD 3A E8 BE 13 C3 D0 5C 03 34 C3 FD F8 31 55 AE 5B 36 D7 84 28 68 2A 26
09 : 59 : 53 SM_TCP SERVICE = AARE
09 : 59 : 53 SM_TCP COSEM OUT DATA
09 : 59 : 53 ====>Tx SM_TCP D0 12 20 00 00 00 00 C0 01 C1 00 07 00 00 5E 5B 0A FF 01 00
09 : 59 : 53 SM_TCP COSEM OUT DATA - CIPHERED
09 : 59 : 53 ====>Tx SM_TCP D0 12 20 00 00 00 00 1D 66 24 F3 04 6A DE CC D6 4F 3A 97 52
09 : 59 : 53 SM_TCP SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 1
09 : 59 : 53 SM_TCP SENDING WRAPPER FRAME
09 : 59 : 53 ====>Tx SM_TCP 00 01 00 20 00 01 00 14 D0 12 20 00 00 00 00 1D 66 24 F3 04 6A DE CC D6 4F 3A 97 52
09 : 59 : 54 SM_TCP RECEIVED WRAPPER FRAME
09 : 59 : 54 <====Rx SM_TCP 00 01 00 01 00 20 00 13 D4 11 20 00 00 00 00 D1 76 C6 46 75 30 C2 88 5E BC 79 67
09 : 59 : 54 SM_TCP RECEIVED APPLICATION LAYER FRAME - CIPHERED
09 : 59 : 54 <====Rx SM_TCP D4 11 20 00 00 00 00 D1 76 C6 46 75 30 C2 88 5E BC 79 67
09 : 59 : 54 <====Rx SM_TCP D4 11 20 00 00 00 00 C4 01 C1 00 09 06 00 00 5E 5B 0A FF
09 : 59 : 54 SM_TCP SERVICE = GET RESPONSE
09 : 59 : 54 SM_TCP COSEM OUT DATA
09 : 59 : 54 ====>Tx SM_TCP D0 12 20 00 00 00 01 C0 01 C1 00 07 00 00 5E 5B 0A FF 02 00
09 : 59 : 54 SM_TCP COSEM OUT DATA - CIPHERED
09 : 59 : 54 ====>Tx SM_TCP D0 12 20 00 00 00 01 99 20 19 DF D4 9B A0 1C A1 11 07 6A C4
09 : 59 : 54 SM_TCP SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 2
09 : 59 : 54 SM_TCP SENDING WRAPPER FRAME
09 : 59 : 54 ====>Tx SM_TCP 00 01 00 20 00 01 00 14 D0 12 20 00 00 00 01 99 20 19 DF D4 9B A0 1C A1 11 07 6A C4
09 : 59 : 55 SM_TCP RECEIVED WRAPPER FRAME
09 : 59 : 55 <====Rx SM_TCP 00 01 00 01 00 20 00 63 D4 61 20 00 00 00 01 E9 E6 97 71 F8 7B DD 94 6C 04 DB 8E C7 F5 29 97 6B 9A 39 BB 7E FE BD ED 15
84 29 6E 63 BF 7F CC 7A 8C 9D 9F C7 BC 90 5B 02 5C 84 76 31 13 08 02 6F 55 CE 63 26 41 4A 13 3E AF E1 91 EA 85 FF 82 27
B0 DF AA 0D C8 B7 8A 32 CF C4 9F 7E E0 95 5B F9 D2 D9 9D 45 B8 FE 59 9E CF C6 D4
09 : 59 : 55 SM_TCP RECEIVED APPLICATION LAYER FRAME - CIPHERED
09 : 59 : 55 <====Rx SM_TCP D4 61 20 00 00 00 01 E9 E6 97 71 F8 7B DD 94 6C 04 DB 8E C7 F5 29 97 6B 9A 39 BB 7E FE BD ED 15 84 29 6E 63 BF 7F CC 7A
8C 9D 9F C7 BC 90 5B 02 5C 84 76 31 13 08 02 6F 55 CE 63 26 41 4A 13 3E AF E1 91 EA 85 FF 82 27 B0 DF AA 0D C8 B7 8A 32
09 : 59 : 55 <====Rx SM_TCP D4 61 20 00 00 00 01 C4 01 C1 00 01 01 02 08 0A 0A 32 30 31 39 30 30 30 30 31 30 0A 0D 45 4C 53 32 30 31 39 30 30 30 30
31 30 0A 1D 45 4C 53 65 77 65 64 79 20 45 6C 65 63 74 72 6F 6D 65 74 65 72 00 00 00 44 31 00 00 28 0A 04 31 35 2E 36 11
06 0A 02 44 31 0A 09 28 35 2D 36 30 29 20 41 00 12 07 E3
09 : 59 : 55 SM_TCP SERVICE = GET RESPONSE
09 : 59 : 55 SM_TCP COSEM OUT DATA
09 : 59 : 55 ====>Tx SM_TCP D0 12 20 00 00 00 02 C0 01 C1 00 07 00 00 5E 5B 0A FF 03 00
09 : 59 : 55 SM_TCP COSEM OUT DATA - CIPHERED
09 : 59 : 55 ====>Tx SM_TCP D0 12 20 00 00 00 02 C9 66 1C 59 01 7C F8 5D A3 0B 9D D2 66
09 : 59 : 55 SM_TCP SERVICE = GET REQUEST, OBIS = 0-0-94-91-10-255, IC = 7, ATTR: INDEX = 3
09 : 59 : 55 SM_TCP SENDING WRAPPER FRAME
09 : 59 : 55 ====>Tx SM_TCP 00 01 00 20 00 01 00 14 D0 12 20 00 00 00 02 C9 66 1C 59 01 7C F8 5D A3 0B 9D D2 66
09 : 59 : 56 SM_TCP RECEIVED WRAPPER FRAME
09 : 59 : 56 <====Rx SM_TCP 00 01 00 01 00 20 00 9E D4 81 9B 20 00 00 00 02 14 65 D1 86 2E 83 FA 16 F0 2C B6 D2 73 A6 6F 15 AD A9 8F 8C D1 C0 E3 86
AA D6 3C 67 1D D7 DA A3 A1 82 50 B6 4C 5A DD F2 26 86 8B E7 51 7B 99 20 9B 68 D1 A3 72 0E 92 6C 02 6B FD 0F 08 85 CB A4
D1 24 9D 6D B6 31 3F 55 BA C0 B3 B6 93 1B C2 99 B8 66 79 73 1C 20 CB 8B B1 42 17 20 CB ED C2 08 B3 05 8D 0A C1 CD 44 D6
1D 87 18 0C DB 4F 42 6D F4 EA 91 72 E0 E9 22 0C B3 95 5D D4 5B D0 88 0C CC BD FC 4C 48 31 DF 87 8C 6D 16 2B E7 7E 29 C4
09 46 61 74 A1 14
09 : 59 : 56 SM_TCP RECEIVED APPLICATION LAYER FRAME - CIPHERED
09 : 59 : 56 <====Rx SM_TCP D4 81 9B 20 00 00 00 02 14 65 D1 86 2E 83 FA 16 F0 2C B6 D2 73 A6 6F 15 AD A9 8F 8C D1 C0 E3 86 AA D6 3C 67 1D D7 DA A3
A1 82 50 B6 4C 5A DD F2 26 86 8B E7 51 7B 99 20 9B 68 D1 A3 72 0E 92 6C 02 6B FD 0F 08 85 CB A4 D1 24 9D 6D B6 31 3F 55
BA C0 B3 B6 93 1B C2 99 B8 66 79 73 1C 20 CB 8B B1 42 17 20 CB ED C2 08 B3 05 8D 0A C1 CD 44 D6 1D 87 18 0C DB 4F 42 6D
F4 EA 91 72 E0 E9 22 0C B3 95 5D D4 5B D0 88 0C CC BD FC 4C 48 31 DF 87 8C 6D 16 2B E7 7E 29 C4 09 46 61 74 A1 14
This is some traces from kalki when i download Nameplate.
And yes its using wrapper.So how can i download from Dlmsdirector
You are also using ciphering. Change Interface from HDLC to WRAPPER.
Authentication level is Low.
Client address is 32 (0x20). Update the block system key and authentication key to correct.
Client system title what you are using is "qwertyui".
MIkko
