  3. How Can I Read First Push From Meter With GXNet?
How can I read first push from meter with GXNet?
By SgmUsr , 28 November, 2019
Gurux.Net
Hi All,
I'm trying to create a server tcp/udp using Gurux.DLMS.Meter.Listener example; when my meter connects to server correctly, it raises OnClientConnected() event but here I can't read the push frame meter sends to the server.
How can I read this first frame with GXNet before GXDLMSReader.ReadAll()?
6 years 9 months ago
Check Gurux.DLMS.Push.Listener.Example.Net if you want to receive push messages.
Gurux.DLMS.Meter.Listener is for connections where meter makes connection to the server.
SgmUsr
Thanks for the response; My
Thanks for the response; My problem is my meter wake up and send push to my server but it raises OnClientConnected() event and I cannot read this first frame.
What method I need to use to read this frame?
6 years 8 months ago
Can you post data that meter sends here?
