  3. Invocation Counter Updation
Invocation Counter updation
By Bhaumik , 21 November, 2019
Gurux.Net
I am trying to connect - disconnect meter multiple times. As meter required Invocation counter value higher than previous value for reconnecting.
I can connect meter from GXDLMSDirector only by giving the updated value of the Invocation counter in device properties.
GXDLMSDirector always takes Invocation counter value as 0 in reconnect.
Is there any other settings in GXDLMSDirector from which it takes updated Invocation Counter value?
6 years 10 months ago
Select "Secured Connections" tab. Set OBIS code where you are reading Invocation Counter to "Frame Counter LN". After that, it's read automatically.
This is not implemented yet for example clients, but it's on progress.
Bhaumik
Is there any way we can reset the Invocation counter?
It depends on the meter. Usually no.
