  3. How To Read Meter Data From Smart Meter Through Uart
How to read meter data from smart meter through uart
By sreeraj , 1 October, 2019
Gurux.Serial
I want to read meter data through uart. how to use this dlmsclientexample.
Please explain step by step
7 years 1 month ago
I believe that you are using ANSI C++ or ANSI C. UART handling depends on the compiler.
You can check an example for Arduino.
https://github.com/Gurux/GuruxDLMS.c/blob/a0cc328ea7fbfa288b45d0e47e497…
sreeraj
7 years 1 month ago
I am using ANSI C. How to compile dlmsclient example
7 years 1 month ago
It depends on what compiler you are using.
sreeraj
7 years 1 month ago
i have one smart meter. how
i have one smart meter. how can read data from that. i am using GXDLMSDirector . But i dont know manufacturer. then what will do?
7 years 1 month ago
You can try to select the Indian standard as a manufacturer and make a connection. Try to connect without authentication first.
sreeraj
7 years 1 month ago
Then it has given error message of 'failed to receive reply from device in a given time'.
Regards
7 years 1 month ago
Are you using serial port connection? Is your cable connected correctly?
Check from the Window settings that drivers are installed correctly for your USB2Serial port.
One of those is usually the reason.
sreeraj
7 years 1 month ago
what is data format getting from dlms meter through serial port while using ANCI C code? Now I am getting continuous "AT "(40 54 0D) only.
Regards
7 years 1 month ago
AT is coming from the modem. You need to talk with DLMS meter. Try to communicate with the meter using the serial port.
sreeraj
6 years 9 months ago
I am reading dlms meter using uart. first i sent Initializing serial connection (7E A0 07 03 21 93 0F 01 7E). then i got response. What is the next command to send, What is command packet to read voltage , current and kwh data. Iam using high authentication dlms meter. Please explain command to read data.
DLMS is not a very simple standard. I strongly recommend that you use our open source libraries to read your values.
You can't send the same bytes several times to read the value. You must increase then packet sequence number and count CRC for each message.
sreeraj
I used your open source libraries to read value. The DLMS meter used high authentication. So where will i put password in code.
You can change the authentication level and password in the constructor.
Someting like:
GXDLMSClient cl = new GXDLMSClient(true, 16, 1, Authentication.Low, "PASSWORD", InterfaceType.HDLC);
You need also change the clent address from 16. If you are using Indian standard change it to 32.
Frank G
3 years 1 month ago
Hi Mikko, is there a Python…
is there a Python Class to read the meter directly over UART (Not over Serial)?
Similar to the class serial, but direct for UART.
Many thanks
Frank
  • Raja Golf - Kantor Pusat | WA 083148835648
  • AB Golf | WA 083148835648
