  3. The Gurux-dlms-master For Android Don't Read Packets From My Meter ( Actaris Electricity )
The Gurux-dlms-master for Android don't read packets from my meter ( actaris electricity )
By kija , 6 September, 2019
Gurux DLMS for Android
7 years 2 months ago
Are you using a serial port or optical probe? Can you send a trace from the message what you are sending?
kija
Why i connect my meter the
When i connect my meter the port is automaticaly allocate and set but the packets send to initialize connection is not recieve by the meter
Yes, but are you using the serial port connection to the meter or optical head (brobe)?
Miko
kija
Connexion port série
kija
Connection to the serial port
Can you read your meter using GXDLMSDirector and same serial port cable?
Connect your meter to the PC and then try with GXDLMSDirector.
kija
Yes with the GLMSDIRECTOR (C#
Yes with the GLMSDIRECTOR (C#) I can read my meter.
There are a few possible reasons for this.
1. Baud rate is wrong.
2. Manufacturer is wrong. Select manufacturer to "Actaris Electricity".
3. We are not supporting your chipset. Check what Chipset you are using selecting "Media settings" and check Chipset and post it here.
Can you connect your Android to PC using serial port? If you can, download example meter from here:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Server.E…
Compile and start it by -S COMX -t Verbose.
Where COMX is serial port what you are using. Try to connect from Android. Are you seeing any trace on server example? If you can, the connection is working and settings are wrong.
kija
This is screenshot of "media
This is screenshot of "media settings" when i connect my meter
When you can connect to the meter using GXDLMSDirector are you using the same USB to the serial port converter? Is there an external power supply in your USB 2 serial port converter?
Is your baud rate the same? You are not using an optical head (probe)?
kija
Yes i am using the same USB
Yes i am using the same USB to the serial port converter. no there is not an external power supply in my USB 2 serial port converter. The baudrate is the same and i am not using and optical head (prode).
  • Raja Golf - Kantor Pusat | WA 083148835648
  • AB Golf | WA 083148835648
