  3. Read Tamper Records From DLMS Meters
Read tamper Records from DLMS meters
By SarbjitSingh , 7 August, 2019
Hello Mikko,
I am able to read tamper event codes from OBIS = 0.0.96.11.e.255 IC = 1, values of e range from 0 to 6). I want to read the detailed event history (logs) for tampered events i.e - tamper logs using (OBIS = 0.0.99.98.e.255 IC = 7, values of e range from 0 to 6). But I am unable to receive the proper response. I am referring IS 15959-2011. Please help me in parsing tamper records along with logs.
Thanks & Regards,
Sarbjit Singh
SarbjitSingh
6 years 11 months ago
Hello Mikko,
Hello Mikko,
Any help on this ?
Sarbjit Singh
Hi Sarbjit,
Hi Sarbjit,
What kind of response you are getting? Is the problem that there is a list of values?
SarbjitSingh
Mikko,
Mikko,
I am getting the following response for the OBIS codes of event log:
Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.0.255 ---- Ch. 0 Event log 1
Entries: 0/80
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.1.255 ---- Ch. 0 Event log 2
Entries: 0/80
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.2.255 ---- Ch. 0 Event log 3
Entries: 48/64
11/07/14 11:03:00:000 | 101 |
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.3.255 ---- Ch. 0 Event log 4
Entries: 0/16
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.4.255 ---- Ch. 0 Event log 5
Entries: 0/40
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.5.255 ---- Ch. 0 Event log 6
Entries: 0/1
But as per the IS 15959-2011 doc it should display the parameters such as date, time, current ,energy, etc. but here no information for log is visible.
Sarbjit Singh
There is no data from 0.0.96.11.e.255 in your log. Try to change authentication level to higher or then it's not implemented for the meter.
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
