  3. Certificates Support
Certificates support
By belen.morenate , 12 July, 2019
Hi all
I wanted to know if it is possible to configure a Dlms Simulator that could work with these functionalities:
- HLS 7 authentication mechanism
- Communication using Static-Unified model
- Communication using One-pass Diffie-Hellman
- APDU ciphering and signature
All using Security Suite 1 ECDH-ECDSA-AES-GCM-128-SHA-256.
Basically the question is if all of this is already implemented in the Gurux.DLMS library and it is feasible make all those functionalities work in a DLMS simulator.
Thanks!
7 years 2 months ago
First: Only Java is supporting certificates at the moment. We are adding support for other programming languages at the moment.
DLMS Simulator doesn't support certificates at the moment. We can modify it and support it September.
belen.morenate
Great thanks!
Great thanks!
Just a remark, what would be necessary for the Java Dlms Simulator to be ready by September? Is it already planned or is it something to be prioritized yet?
Regarding Suite 1 support on .Net, do you have a date or roadmap?
Thanks!
For java, we need just modify example and add certificates. All the functionality is already in the use of our clients.
For other programming languages, we have planned to add support during this year.
