By Amiya , 29 May, 2019 Forums General discussion Dear sir, kindly tell me one meter name which is support for remote connect/disconnect Hi, Hi, There are several meter manufacturers that are supporting remote connect/disconnect. BR, Mikko kindly tell me some kindly tell me some manufacturers name . Hi, Hi, Example Genus is supporting that. BR, Mikko Except Genus ,is there any Except Genus ,is there any meter support it? Hi, Hi, Several meters are supporting it. You need to ask this info from the meter vendor. BR, Mikko Hii, Hii, kindly tell me the client id and server id for AEC meters which is manufacture from SEC(Saudi Electric Company). Hi, Hi, You can use values: client address: 16 (0x19) server address: 1. BR, Mikko This Attribute is not working This Attribute is not working for me..Is there any other way.. Hi, Hi, Are you getting any reply from the meter? Are you connecting using an optical probe or serial port? BR, Mikko
kindly tell me some
Hii,
Hii,
You can use values:
server address: 1.
