  3. Trying To Import Active Maximum Demand
By ahsensaeed , 8 April, 2019
Hey there, I'm trying to read Import Active maximum demand from my smart meter but unfortunately, it gives me the error bytes. My smart meter model is DTSD545 and company manufacturer is Holley Metering System.
First, I read the Maximum Demand from Gurux Director. I attach the screenshot. It successfully gives me the value of demand but when I try to read the maximum demand from my program it gives me an error. The following how I try to read value.
GXDLMSRegister register = new GXDLMSRegister("1.0.1.6.0.255");
byte[] bytes = gxdlmsClient.read(register, 2)[0]
readDLMSPackaet(bytes)
Below are the bytes which my program sent to meter.
00 01 00 11 00 01 00 0D C0 01 C1 00 03 01 00 01 06 00 FF 02 00
And the following shows what smart meter sends the response to my program.
00 01 00 01 00 11 00 05 C4 01 C1 01 09
Can you please tell me what I'm doing wrong?
Best Regards,
Ahsen Saeed.
7 years 7 months ago
Can you read everything else from this class? In the pic you have read other values.
I believe that you are not doing anything wrong.
This attribute is not implemented to the meter and meter returns error from that.
You should check this from the meter vendor.
ahsensaeed
Hey Mikko,
Hey Mikko,
What do you mean by "This attribute is not implemented to the meter and meter returns error from that". I'm successfully able to read the Import Active Energy, Voltage and other values same as you I try to read Maximum Demand.
Best Regards,
Ahsen Saeed
Are you using the same authentication level as GXDLMSDirector? Have you made handshaking sending AARQ and check AARE messages before reading value?
ahsensaeed
Hey Mikko,
Hey Mikko,
Below is my authentication settings for GxDLSMClien.
fun gxDLmsClient(): GXDLMSClient {
val dLMSClient = GXDLMSClient()
dLMSClient.useLogicalNameReferencing = true
dLMSClient.interfaceType = InterfaceType.WRAPPER
dLMSClient.serverAddress = 1
dLMSClient.clientAddress = 17
dLMSClient.authentication = Authentication.LOW
dLMSClient.setPassword("00000000")
return dLMSClient
ahsensaeed
Hey Mikko,
Hey Mikko,
Yes, I made handshaking and successfully send the AARQ request to meter.
Hi Ahsen,
Hi Ahsen,
I just notest that your class is GXDLMSRegister. It should be extended register.
GXDLMSExtendedRegister register = GXDLMSExtendedRegister("1.0.1.6.0.255");
ahsensaeed
Hey Mikko,
Hey Mikko,
Thank you so much it works great. Now that it works I wanna know what's the difference between GxDLMSRegister and ExtendedGXDLMSRegister?
Best Regards,
Ahsen Saeed
Content is different. They are totally different registers,
