  3. Getting Null Object In ReadScalerAndUnits() Method
Getting Null object in readScalerAndUnits() method
By rahul.singh@ra… , 24 January, 2019
void readScalerAndUnits() throws Exception {
GXDLMSObjectCollection objs = dlms.getObjects()
.getObjects(new ObjectType[] { ObjectType.REGISTER,
ObjectType.DEMAND_REGISTER,
ObjectType.EXTENDED_REGISTER });
try {
if (dlms.getNegotiatedConformance()
.contains(Conformance.MULTIPLE_REFERENCES)) {
List<Entry<GXDLMSObject, Integer>> list =
new ArrayList<Entry<GXDLMSObject, Integer>>();
for (GXDLMSObject it : objs) {
if (it instanceof GXDLMSRegister) {
list.add(new GXSimpleEntry<GXDLMSObject, Integer>(it,
3));
if (it instanceof GXDLMSDemandRegister) {
4));
readList(list);
Unable to add readList .
i amd using sample client java .
Please Help
7 years 10 months ago
On what row you are getting this error? Have you made any changes?
rahul.singh@ra…
In reply to Getting Null object in readScalerAndUnits() method by Kurumi
Hi Mikko
Hi Mikko
Am not getting any error .
it just data in ReadAll() Method we can only able to read AssociativeView .
I believe that you have connected using Authentication None. Some meters don't return any registers with that authentication. You need to change authentication to Low or High and try again.
You can test this with GXDLMSDirector.
rahul.singh@ra…
static int getParameters(String[] args, Settings settings) {
GXNet net = null;
settings.client.setInterfaceType(InterfaceType.HDLC);
settings.client.setUseLogicalNameReferencing(true);
settings.media = new GXNet();
net = (GXNet) settings.media;
net.setHostName("192.168.54.32");
net.setPort(Integer.parseInt("1234"));
settings.client.setPassword("ABCD0001".getBytes());
settings.iec = false;
settings.client.setAuthentication(Authentication.valueOfString("Low"));
settings.client.setClientAddress(Integer.parseInt("29"));
settings.client.setServerAddress(Integer.parseInt("01"));
return 0;
i have used authentyication = LOw
Somewhere else i need to mention .
I am using Gurux java client example
Is list empty of what exactly is the problem?
rahul.singh@ra…
Yes list is empty for
Yes list is empty for readandscal.
rahul.singh@ra…
7 years 9 months ago
If the list is empty there are no registers. Try to connect using higher authentication level.
I believe that you are using authentication level None.
rahul.singh@ra…
Am Using LOW Authentication
Tried With
settings.client.setAuthentication(Authentication.valueOfString("LOW"));
1. settings.client.setPassword("ABCD0001".getBytes("ASCII"));
2. settings.client.setPassword("ABCD0001".getBytes());
3. settings.client.setPassword("ABCD0001");
rahul.singh@ra…
Tried With
Try to connect with High Authentication. Problem is that there are no register objects in the association view.
