  3. Length of RLRQ Is Not Correct If Using HLS With Security Suite 0
Length of RLRQ is not correct if using HLS with Security Suite 0
By panny2406 , 12 December, 2018
Hi there,
we´ve problems using HLS with Security Suite 0 (Library Version 2.2.17).
We are able to initialize the connection, it is even possible to do some get requests, but whenever we close the connection we get a "Length of RLRQ is not correct". There are no problems when using HLS Security Suite 1 or 2.
We use HLS with Authentication (HIGH_GMAC) and Encryption against the Meter Simulator of DNV GL.
Does anyone have an idea why this error occurs?
We use the following code:
GXDLMSSecureClient client = new GXDLMSSecureClient();
client.setInterfaceType(InterfaceType.WRAPPER);
client.setAuthentication(Authentication.HIGH_GMAC);
client.setClientAddress(1);
client.setServerAddress(1);
client.setUserId(1);
client.setPassword(Util.hexStringToByteArray("30313233343536373839414243444546"));
client.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
client.getCiphering().setAuthenticationKey(Util.hexStringToByteArray("00112233445566778899AABBCCDDEEFF"));
client.getCiphering().setBlockCipherKey(Util.hexStringToByteArray("00112233445566778899AABBCCDDEEFF"));
// If we use Authentication and Encryption with HIGH_GMAC and Security Suite 0 we get an error closing the connection
// (Length of RLRQ is not correct) for Meter Simulator
client.getCiphering().setSecuritySuite(SecuritySuite.AES_GCM_128);
// client.getCiphering().setSecuritySuite(SecuritySuite.ECDH_ECDSA_AES_GCM_128_SHA_256);
// client.getCiphering().setSecuritySuite(SecuritySuite.ECDHE_CDSA_AES_GCM_256_SHA_384);
IGXMedia media = new GXNet(NetworkType.UDP, "192.168.0.20", 4059);
When we initialize and close the connection with the code of your sample client we get the following payloads (already decoded with your Translator):
Req:
00 01 00 01 00 01 00 64 60 62 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47
48 A9 03 02 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 3F 70 0F 30 03 27 1D 14 4B
3F 53 68 57 20 3C 2A BE 23 04 21 21 1F 30 00 00 00 00 60 88 10 05 D1 E8 59 6B 59 70 01 46 8D 72
B7 8A 52 E6 5E A7 EF 9E 7F 05 17 89
<WRAPPER len="108" >
<TargetAddress Value="1" />
<SourceAddress Value="1" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="4142434445464748" />
<CallingAEInvocationId Value="1" />
<MechanismName Value="HighGMac" />
<CallingAuthentication Value="3F700F3003271D144B3F536857203C2A" />
<glo_InitiateRequest Value="300000000060881005D1E8596B597001468D72B78A52E65EA7EF9E7F051789" />
</AssociationRequest>
</PDU>
</WRAPPER>
Res:
00 01 00 01 00 01 00 76 61 74 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01
0E A4 0A 04 08 44 4E 56 67 73 16 5C 86 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 1D 80 1B 2E 2C
7A 68 66 5A 22 3A 4A 30 5B 44 78 62 37 64 38 53 56 57 46 35 5B 43 72 76 40 BE 23 04 21 28 1F 30
00 00 19 47 96 BD D5 D0 48 15 75 5B FE 5A 52 78 39 CB D3 A3 0A 51 37 B1 1E 2F 93 7D E3 31
<WRAPPER len="126" >
<PDU>
<AssociationResponse>
<AssociationResult Value="0" />
<ResultSourceDiagnostic>
<!--AUTHENTICATION_REQUIRED-->
<ACSEServiceUser Value="14" />
</ResultSourceDiagnostic>
<RespondingAPTitle Value="444E566773165C86" />
<RespondingAuthentication Value="2E2C7A68665A223A4A305B44786237643853565746355B43727640" />
<glo_InitiateResponse Value="300000194796BDD5D04815755BFE5A527839CBD3A30A5137B11E2F937DE331" />
</AssociationResponse>
</PDU>
</WRAPPER>
Req:
00 01 00 01 00 01 00 33 CB 31 30 00 00 00 00 A2 89 D1 05 D8 B7 46 47 59 70 E0 5A 73 84 44 F7 01
09 EF 91 6F B8 B5 67 72 37 2F 7D 1F 31 A9 F6 E0 93 80 99 54 26 37 38 32 40 F1 E9
<WRAPPER len="59" >
<PDU>
<glo_ActionRequest Value="3000000000A289D105D8B746475970E05A738444F70109EF916FB8B56772372F7D1F31A9F6E0938099542637383240F1E9" />
</PDU>
</WRAPPER>
Res:
00 01 00 01 00 01 00 2C CF 2A 30 00 00 19 49 F0 54 B1 C2 48 A7 C6 A6 D6 DE DE 6E 73 DD 98 3F DA
6A 7F BA C6 EC 11 9A 5E E4 3B 6C B0 32 7D 12 7E E3 62 34 08
<WRAPPER len="52" >
<PDU>
<glo_ActionResponse Value="3000001949F054B1C248A7C6A6D6DEDE6E73DD983FDA6A7FBAC6EC119A5EE43B6CB0327D127EE3623408" />
</PDU>
</WRAPPER>
Req:
00 01 00 01 00 01 00 3D 62 3B 30 00 00 00 00 03 A0 90 04 D7 09 65 6B 78 51 00 6B 72 8D 55 E7 61
81 FF 94 6C C4 E2 DD 22 9A B8 12 9E 01 9F 4F 7B C0 CE A9 68 66 DD 0C 9A 46 23 FE 75 32 7B 12 9D
B0 E7 3D 40 A3
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Invalid DLMS framing.
Res:
00 01 00 01 00 01 00 03 D8 01 01
<WRAPPER len="11" >
<PDU>
<Data="0101" />
</PDU>
</WRAPPER>
BR
Christoph
7 years 11 months ago
I'll check this today.
This is fixed. Get the latest version 2.2.20.
https://gurux.fi/node/13078
panny2406
I can confirm that this works with version 2.2.20.
Thank you very much
Christoph
  • Toko Tiga Saudara | WA 083148835648
  • Tb. Laris Jaya | WA 083148835648
