  3. Implementing MDC For Electric Meters For On Demand Pull and Scheduled Push and Write Requests
Implementing MDC for Electric Meters for on Demand Pull and scheduled Push and Write Requests
By kashif.ir , 30 November, 2018
We want to implement MDC for Electric Meters for on Demand Data Fetching from Meters, To record data pushed by Energy meter on scheduled interval or on alert and to write configuration to the meter.
I am programmer, I have explored the code of GURUX DLMS, although the library is good enough that it worth to utilized it, but only lacking point is that there is no proper documentation available and it could only be the reason to not utilize this library in our Project.
But I have came across this forum and for my last hope I am considering this forum if I could get help in implementation of my desired requirement.
I want to use Java as my programming platform.
7 years 11 months ago
All the interfaces are documented on the standard. There is no point that we re-write standard. Each meter is different and users have different needs. For this reason, we have this forum. If you need help you can ask.
You can get started reading this:
http://gurux.fi/Gurux.DLMS.Client
kashif.ir
Message Format send by Energy Meter
b'\x00\x01\x00\x01\x00\x01\x00\x10\n\x02\n1721025659\x00B}'
I have received above message (Hex Byte Array) by meter to server. I need to know what is this message format? In response to this message which message should I send back to meter?
I also need to know if I want to get Positive Active Energy from meter (OBIS Code 1.8.0) which message should I send to meter?
I don't know what protocol your meter is using. This is not DLMS. You need to find out what protocol your meter is using.
