  3. Addressing
Addressing
Profile picture for user hassin Ayaz
By hassin Ayaz , 24 December, 2017
Gurux.Net
Hello ,
I have a problem regarding server(meter) addressing
in the raw HDLC frame
the destination address should be 0x00 0x02 0x00 0x03 &
the source address should be 0x03
in order to do the the above what should be the ServerAddress in the Gurux.DLMS.METER.Listener.Net example code ? here is the code snippet
GXDLMSClient client = new GXDLMSClient();
client.UseLogicalNameReferencing = true;
client.Authentication = Enums.Authentication.None;
client.Password = null;
client.InterfaceType = Enums.InterfaceType.HDLC;
client.ClientAddress = 0x01; //this is okay
client.ServerAddress = 0x0001; //I am stuck here
Thank you
8 years 5 months ago
Addressing
client.ServerAddress = 0x4001;
hassin Ayaz
Addressing
Hi ,
Thanks a Lot
it has worked
BR
Hassin Ayaz
hassin Ayaz
8 years 1 month ago
Addressing
Dear Mr Kurumi
I want to understand how gurux calculates logical address of the server address
For example if i put the following values at GXDLMSDirector Software
client address = 1= 0x01
logical server = 1= 0x01
physical server = 10 = 0x10
Then According to DLMS address theory , for 2 byte address size
in the HDLC frame
client address should be 0x03
locical address should be 0x02
physical address should be 0x21
the generated hdlc snrm frame by GXDLMSDirector software is
0x7E 0xA0 0x08 0x02 0x21 0x03 0x93 0x86 0xC1 0x7E
this is okay ,it matches with the theory
but in the C# client code the output frame does not match
here is my code snippet
client.ServerAddressSize = 2;
client.ServerAddress = 0x0110;
and here is the output hdlc snrm frame
Send SNRM request.0x7E 0xA0 0x08 0x04 0x21 0x03 0x93 0x1C 0x8A 0x7E
So does the client code calculated address differenlty than the GX software ?
It would be great if you reply
Thanks A Lot & Best regards
Hassin AYaz
hassin Ayaz
8 years 1 month ago
Addressing
Dear Mr Kurumi
i have an update . using server.address = 0x4010 , 4 byte server address was generated and meter accepted that too
Thank you & best regards
hassin ayaz
8 years 1 month ago
I have described how counting address here:
http://www.gurux.fi/dlmsAddress
You can count server address
GXLMDSClient.GetServerAddress(logical, physical);
hassin Ayaz
8 years 1 month ago
Addressing
Dear Mr Kurumi ,
thanks a lot for the explanation .
hassin Ayaz
7 years 7 months ago
Addressing
Hello Mr Kurumi
i am trying to connect to a DCU using GXDLMSDirector Desktop Software
The DCU communicates with its own software and the SNRM packet sent by its software is
7E A0 21 00 02 22 23 03 93 ....
what should be the "Physical Server" Value in the GxDirector software
to generate the same Physical address raw packet 0x22 0x23 ?
thanks in advance
Addressing
Client address: 1
Logical Server address: 1
Physical server address: 2193 (0x891)
hassin Ayaz
Addressing
Thanks A Lot Mr Kurumi .
server address has matched
