  3. Description of OBIS Code In Dlms Client For Java
Description of OBIS code in dlms client for java
By sakshi , 29 May, 2018
I want to know where are obis code descriptions available in dlms client for java?
When i run dlms client i get logical name and class name. But it gives "invalid" description for all.
8 years 5 months ago
Can you give example from the OBIS code that you are using? All OBIS codes are described on OBISCodes.txt file.
sakshi
In reply to Description of OBIS code in dlms client for java by Kurumi
output-:
output-:
Reading -> GXDLMSRegister , name : 1.0.91.7.0.255 , descriprtion : Invalid
Reading -> GXDLMSRegister , name : 1.0.12.7.0.255 , descriprtion : Invalid
1.0.91.7.0.255 is for Neutral Current
1.0.12.7.0.255 for voltage
But it is giving "descriprtion : Invalid"
I just verify this:
1.0.91.7.0.255: Ch. 0 Lo Current (neutral) Inst. value
1.0.12.7.0.255: Ch. 0 Voltage: any phase Inst. value
Have you made changes to the source code? What version are you using?
GXDLMSConverter t = new GXDLMSConverter();
Object val1 = t.getDescription("1.0.91.7.0.255", ObjectType.REGISTER);
Object val2 = t.getDescription("1.0.12.7.0.255", ObjectType.REGISTER);
sakshi
No i dint change anything in
No i dint change anything in source code.
<artifactId>gurux.dlms.client.example.java</artifactId>
<version>0.0.1-SNAPSHOT</version>
I have also tried below code.
It is giving invalid.
Hi,ยจ
What is your gurux.dlms component version?
<groupId>org.gurux</groupId>
<artifactId>gurux.dlms</artifactId>
<version>2.2.10</version>
sakshi
It is 2.2.9.
<version>2.2.9</version>
sakshi
I have changed the version to 2.2.10 in pom.xml
Now it is giving correct description.
Thankyou
