  3. Gurux.DLMS.cpp Where To Start
Gurux.DLMS.cpp where to start
By Anto sujesh , 15 February, 2018
Am new to DLMS programming. i need to get Voltage (V1) from the meter using Gurux.DLMS.cpp.
In GitHub i can see GuruxDLMSClientExample, GuruxDLMSPushExample, GuruxDLMSServerExample so which project i should use and where to start. i know its a very basic question. plz guide me to start it.
Am from India
Meter Information
Sprint 350
Type : E3D109
S.No : Y0517221
8 years 9 months ago
If you want to read your meter you should use GuruxDLMSClientExample. You need to set right parameters of the meter is not answering anything.
Anto sujesh
Reading Meter
i tried following settings. but still i cant able to get any response. i can only see ShowHelp() function. GXDLMSDirector sample is working fine with this settings
<WaitTime>7</WaitTime>
<Authentication>Low</Authentication>
<Password>HgjgLgmwzrHfQnEjli2QqQ==</Password>
<PhysicalAddress xsi:type="xsd:int">256</PhysicalAddress>
<LogicalAddress>1</LogicalAddress>
<ClientAddress>32</ClientAddress>
<StartProtocol>DLMS</StartProtocol>
<WindowSizeTX>1</WindowSizeTX>
<WindowSizeRX>1</WindowSizeRX>
<InactivityTimeout>120</InactivityTimeout>
<Name>secure1</Name>
<Verbose>false</Verbose>
<Conformance>7709</Conformance>
<Manufacturer>EHL</Manufacturer>
<HDLCAddressing>0</HDLCAddressing>
<MediaType>Gurux.Serial.GXSerial</MediaType>
<MediaSettings>&lt;Port&gt;COM5&lt;/Port&gt;&lt;StopBits&gt;1&lt;/StopBits&gt;</MediaSettings>
C# code :
Settings settings = new Settings();
settings.client.Authentication = Authentication.Low;
settings.client.ClientAddress = 32;
settings.client.ServerAddress = 1;
settings.client.InterfaceType = InterfaceType.HDLC;
settings.client.UseLogicalNameReferencing = true;
settings.client.Password = ASCIIEncoding.ASCII.GetBytes("HgjgLgmwzrHfQnEjli2QqQ==");
Reader.GXDLMSReader reader = null;
try
//Handle command line parameters.
int ret = GetParameters(args, settings);
if (ret != 0)
return ret;
//Initialize connection settings.
if (settings.media is GXSerial)
GXSerial serial = settings.media as GXSerial;
serial.PortName = "COM5";
serial.BaudRate = 9600;
serial.DataBits = 8;
serial.Parity = System.IO.Ports.Parity.None;
serial.StopBits = System.IO.Ports.StopBits.One;
else
throw new Exception("Unknown media type.");
reader = new Reader.GXDLMSReader(settings.client, settings.media, settings.trace);
settings.media.Open();
if (settings.readObjects.Count != 0)
reader.InitializeConnection();
reader.GetAssociationView(false);
foreach (KeyValuePair<string, int> it in settings.readObjects)
object val = reader.Read(settings.client.Objects.FindByLN(ObjectType.None, it.Key), it.Value);
reader.ShowValue(val, it.Value);
else
reader.ReadAll(false);
catch (Exception ex)
Console.WriteLine(ex.Message);
Console.WriteLine(ex.ToString());
if (System.Diagnostics.Debugger.IsAttached)
Console.ReadKey();
return 1;
finally
if (reader != null)
reader.Close();
Console.WriteLine("Ended. Press any key to continue.");
Console.ReadKey();
return 0;
plz guide me
Reading Meter
Your password is not correct.
Anto sujesh
Reading Meter
hi, thank you for the reply. i updated the password. still it shows showHelp();
int ret return 1 and List Parameters count is zero | settings.media is null
if (ret != 0)
return ret;
My C# code :
settings.client.Password = ASCIIEncoding.ASCII.GetBytes("ABCD0001");
try
if (ret != 0)
return ret;
}else {
else
Console.ReadKey();
return 1;
finally
if (reader != null)
reader.Close();
Console.ReadKey();
return 0;
static int GetParameters(string[] args, Settings settings)
string[] tmp;
List<GXCmdParameter> parameters = GXCommon.GetParameters(args, "p:s:c:s:r:it:a:wP:g:S:C:");
GXNet net = null;
foreach (GXCmdParameter it in parameters)
switch (it.Tag)
case 'w':
settings.client.InterfaceType = InterfaceType.WRAPPER;
break;
case 'r':
if (string.Compare(it.Value, "sn", true) == 0)
settings.client.UseLogicalNameReferencing = false;
else if (string.Compare(it.Value, "ln", true) == 0)
else
throw new ArgumentException("Invalid reference option.");
break;
case 'h':
//Host address.
if (settings.media == null)
settings.media = new GXNet();
net = settings.media as GXNet;
net.HostName = it.Value;
break;
case 't':
//Trace.
try
settings.trace = (TraceLevel)Enum.Parse(typeof(TraceLevel), it.Value);
catch (Exception)
throw new ArgumentException("Invalid trace level option. (Error, Warning, Info, Verbose, Off)");
break;
case 'p':
//Port.
net.Port = int.Parse(it.Value);
break;
case 'P'://Password
settings.client.Password = ASCIIEncoding.ASCII.GetBytes(it.Value);
break;
case 'i':
//IEC.
settings.iec = true;
break;
case 'g':
//Get (read) selected objects.
foreach (string o in it.Value.Split(new char[] { ';', ',' }))
tmp = o.Split(new char[] { ':' });
if (tmp.Length != 2)
throw new ArgumentOutOfRangeException("Invalid Logical name or attribute index.");
settings.readObjects.Add(new KeyValuePair<string, int>(tmp[0].Trim(), int.Parse(tmp[1].Trim())));
break;
case 'S'://Serial Port
settings.media = new GXSerial();
tmp = it.Value.Split(':');
serial.PortName = tmp[0];
if (tmp.Length > 1)
serial.BaudRate = int.Parse(tmp[1]);
serial.DataBits = int.Parse(tmp[2].Substring(0, 1));
serial.Parity = (Parity)Enum.Parse(typeof(Parity), tmp[2].Substring(1, tmp[2].Length - 2));
serial.StopBits = (StopBits)int.Parse(tmp[2].Substring(tmp[2].Length - 1, 1));
else
serial.Parity = Parity.None;
serial.StopBits = StopBits.One;
break;
case 'a':
try
if (string.Compare("None", it.Value, true) == 0)
settings.client.Authentication = Authentication.None;
else if (string.Compare("Low", it.Value, true) == 0)
else if (string.Compare("High", it.Value, true) == 0)
settings.client.Authentication = Authentication.High;
else if (string.Compare("HighMd5", it.Value, true) == 0)
settings.client.Authentication = Authentication.HighMD5;
else if (string.Compare("HighSha1", it.Value, true) == 0)
settings.client.Authentication = Authentication.HighSHA1;
else if (string.Compare("HighSha256", it.Value, true) == 0)
settings.client.Authentication = Authentication.HighSHA256;
else if (string.Compare("HighGMac", it.Value, true) == 0)
settings.client.Authentication = Authentication.HighGMAC;
else
throw new ArgumentException("Invalid Authentication option: '" + it.Value + "'. (None, Low, High, HighMd5, HighSha1, HighGMac, HighSha256)");
catch (Exception)
break;
case 'C':
try
settings.client.Ciphering.Security = (Security)Enum.Parse(typeof(Security), it.Value);
catch (Exception)
throw new ArgumentException("Invalid Ciphering option. (None, Authentication, Encrypted, AuthenticationEncryption)");
break;
case 'o':
break;
case 'c':
settings.client.ClientAddress = int.Parse(it.Value);
break;
case 's':
settings.client.ServerAddress = int.Parse(it.Value);
break;
case '?':
switch (it.Tag)
case 'c':
throw new ArgumentException("Missing mandatory client option.");
case 's':
throw new ArgumentException("Missing mandatory server option.");
case 'h':
throw new ArgumentException("Missing mandatory host name option.");
case 'p':
throw new ArgumentException("Missing mandatory port option.");
case 'r':
throw new ArgumentException("Missing mandatory reference option.");
case 'a':
throw new ArgumentException("Missing mandatory authentication option.");
case 'S':
throw new ArgumentException("Missing mandatory Serial port option.");
case 't':
throw new ArgumentException("Missing mandatory trace option.");
case 'g':
throw new ArgumentException("Missing mandatory OBIS code option.");
case 'C':
throw new ArgumentException("Missing mandatory Ciphering option.");
default:
ShowHelp();
return 1;
default:
ShowHelp();
return 1;
ShowHelp();
return 1;
return 0;
