  3. Scaler
Scaler
By hejmaniok , 5 December, 2017
I try to read ReactivePower from Load profile. ReactivePower has a scaler of 0.1 and from the blue book I can see that the unit is var-hour. I was wondering if the value that I read from the meter is already multiplied by scaler or do I have to multiply it by 0.1 to get to var-hour unit?
8 years 7 months ago
Scaler
If you read unit and scaler first (attribute index 3), it's done automatically.
hejmaniok
Thanks for the reply. This
Thanks for the reply. This makes sense.
I have one more question regarding scaler and unit. I am trying to save those to database and when I do this:
if (it.getObjectType() == ObjectType.REGISTER || it.getObjectType() == ObjectType.EXTENDED_REGISTER) {
GXDLMSRegister reg = (GXDLMSRegister) it;
object.put("scaler", reg.getScaler());
object.put("unit", reg.getUnit());
Scaler is read fine but Unit always becomes `NoUnit`. Do you know what could be possibly wrong here?
As a note, when I read REGISTRIES using Gurux Director unit is displayed correctly.
Scaler
You need to read it first.
client.Read(it, 3);
hejmaniok
Yes, and for that I am using
Yes, and for that I am using `readScalerAndUnits()` method from the Gurux official example.
This should be enough right?
Scaler
Can you compare same OBIS codes using GXDMSDirector and Java. They should be same.
hejmaniok
If I use example client and use readRowsByRange is scaler automatically applied?
hejmaniok
If I use example client found on your GitHub and use readRowsByRange is scaler automatically applied?
scaler
Yes, it's scaler s used automatically if the target is Register and scaler is read.
hejmaniok
In my case I read
In my case I read ProfileGeneric and I don't know if the values I receive are already multiplied by scalers.
hejmaniok
Ok I figured this one out.
Ok I figured this one out. When I read ProfileGeneric only using readRowsByRange, scalers are not automatically applied.
Thanks for your help Mikko
scaler
If the register is found from association view and it's read scaler is used automatically also with Profile Generics.
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
