  3. Regarding DLMS Meter Reading Through Serial Communication
Regarding DLMS meter reading through serial communication
By harikrishna , 8 December, 2017
Gurux.Serial
I am planning to Read DLMS Meter from ANSI C++ application.
please let me know how can i setup serial connection.
please guide me how to proceed .
Thanks & Regards,
harikrishna.
8 years 11 months ago
Hi, I believe that you are using Indian standard.
Download GuruxDLMSClientExample from Github and run it.
harikrishna
In reply to Regarding DLMS meter reading through serial communication by Kurumi
I have downloaded the GuruxDLMSClientExample. Can I directly communicate with the meter by using this client example code or is there any need of other source to communicate the meter?
Thanks & Regards,
harikrishna
harikrishna
Dear Mikko,
Is there any code in C language for client side in dlms metering?
Thanks & Regards,
Yes, we have, but that is not open source. Send an email to me if you want to receive the proposal.
You can get my email address from here:
http://www.gurux.fi/AboutUs
In reply to Regarding DLMS meter reading through serial communication by harikrishna
Set correct parameters and you can communicate with your meter.
harikrishna
Dear sir,
I have SNRM, AARQ , clock association command and obis codes. How can we get the the data from dlms meter with the help of these command? How can we make the frame of commands to get the data from dlms meter? We need guidance on this because we are not able to make the commands with logic's. Please help us out.
Thanks & Regards,
DLMS is very complicated protocol. You don't just send few bytes and get a reply. You can study the source code, but I believe that it's easier if you use our stack.
jeet
DLMS Java Code
Hi I executed java code i.e. gurux.dlms.client.example.java. it compiled perfectly but when i am giving parameters on command line i.e. jeet -S COM1 -c 16 -s 1 -a None then showing Invalid parameter jeet
can you tell me where i am making mistake and what should i do to read meter using your java code
Thanks & Regards:
Jeet
DLMS Java Code
Please, if you have a question make a new topic. Parameters depend on the meter you try to read.
If parameters are wrong meter is now answering anything. You should also check your serial port settings. Baudrate, etc.
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
  • ASIA GOLF Driving Range Intercon | WA 083148835648
