  3. How To Change Password of HPL Meter
How to change password of HPL meter
By Goutam , 25 August, 2017
HI,
Following code I have use to change the password in HPL meter
GXDLMSAssociationLogicalName passwordconfig = (GXDLMSAssociationLogicalName)GXDLMSSecureClient.CreateObject(ObjectType.AssociationLogicalName);
passwordconfig.Secret = ASCIIEncoding.ASCII.GetBytes("XXXXXXXXXXXXXXXX");
passwordconfig.HlsSecret = ASCIIEncoding.ASCII.GetBytes("YYYYYYYYYYYYYYYY");
grxComm.Write(passwordconfig, 2);
Result: "Access Error : Device reports a unavailable object."
Could you please suggest me where I am wrong.
If possible could you please provide me sample code.
9 years 2 months ago
You can try with this:
GXDLMSAssociationLogicalName ln = new GXDLMSAssociationLogicalName();
ln.Secret = ASCIIEncoding.ASCII.GetBytes("XXXXXXXXXXXXXXXX");
grxComm.Write(ln, 7);
Goutam
In reply to How to change password of HPL meter by Kurumi
I have checked that the following codes execute successfully.
ln.HlsSecret= ASCIIEncoding.ASCII.GetBytes("YYYYYYYYYYYYYYYY");
But the problem is that the device throw exception "Access Error : Other Reason." when try to authenticate the connection with the High Level Passowrd("YYYYYYYYYYYYYYYY"),Client Address:48 and Authentication:High.
In reply to How to change password of HPL meter by Goutam
First try to read your value. If you can, then contact your meter manufacturer and ask is it possible to change password.
Goutam
Following exception has been thrown when i tried to read
var data = grxComm.Read(ln, 7);
Exception: "Access Error : Device reports Read-Write denied."
What authentication level you are using? What client address you are using?
Goutam
Client Address: 48
Authentication Level: High
Note: For Low Level its working fine. But for high level password its not working.
Hi Goutam,
I did't notes that you was trying to change High authentication level password. You are using method command to set it, not write. Write is used when Low level pw is changed.
We'll add new method (UpdateSecret) to GXDLMSAssociationLogicalName that you can use to change pw.
It'll take care from authentication level. We'll release new version from C# tomorrow.
Goutam
I have update to new version but I have not found any method like 'UpdateSecret' . I have checked that the 'HlsSecret' property has been removed.
Now system failed to ParseAAREResponse after update.
Exception : "Connection is permanently rejected. No reason is given"
Please suggest.
What version you are using and you are using C#?
You set password to Secret property.
You can use it like this:
GXDLMSAssociationLogicalName c = new GXDLMSAssociationLogicalName("OBIS code");
c.AuthenticationMechanismName.MechanismId = Authentication.High;
c.UpdateSecret(client);
Goutam
Thank you,
Sample code is working.
First time i have checked on version 'Gurux.DLMS.8.5.1708.2201'.
Again I update to 'Gurux.DLMS.8.5.1709.1201'.
Now its working with latest version.
Hi Goutam,
Thanks from this info.
  • Tb. Laris Jaya | WA 083148835648
