  3. Authentication Encryption Not Working
Authentication encryption not working
By yatingarg168 , 1 August, 2017
I used different authentication key in my server and client application. Server still is able to decrypt and authenticate the requests. However if I change the Security level just to AUTHENTICATION, it is working correctly and giving an exception.
Yatin
9 years 1 month ago
Authentication key is used to encrypt data.
Your authentication key must be same on client and server.
If that is different communication is not working.
yatingarg168
9 years 1 month ago
At present for POC purpose I wanted to test if I use wrong authentication key, will the GXDLMSServerExample2 be throwing an exception. It does throw in case i set the security level to AUTHENTICATION but it doesnt do so in case secruity level is set to AUTHENTICATION_ENCRYPTION.
Yatin
9 years ago
Your secure settings are not correct. Decrypted data is wrong. Check that BlockCipherKey and AuthenticationKey are correct.
