  3. ServiceError Read Exception. Service Unsupported
ServiceError Read exception. Service Unsupported
By viraj khade , 12 July, 2017
i try to read EDMI MK6E.
Read scalers and units from the device.
7E A0 74 03 41 DA 17 C4 E6 E6 00 C0 03 C1 0A 00 03 00 00 00 01 02 FF 03 00 00 03 00 00 5E 5B 08 FF 03 00 00 04 01 00 01 06 00 FF 03 00 00 03 01 00 01 07 00 FF 03 00 00 03 01 00 01 08 00 FF 03 00 00 04 01 00 02 06 00 FF 03 00 00 03 01 00 02 08 00 FF 03 00 00 03 01 00 03 07 00 FF 03 00 00 03 01 00 05 08 00 FF 03 00 00 03 01 00 06 08 00 FF 03 00 C0 1C 7E
EDMI MK6E (DLMS Protocal) and communicate with Gurux GXDLMS Director.
9 years ago
EDMI MK6E is not supporting DLMS. You can't read it with GXDLMSDirector.
viraj khade
9 years ago
Read data from meter using GXDLMSDirector.
GXDLMSDirector 8.0.1706.1107
Log created 16:38:31
16:38:35 Initializing serial connection.
16:38:35 Send SNRM request.
7E A0 0F 03 41 93 82 81 81 80 03 06 01 80 6B 66 7E
16:38:35 Received data
7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
16:38:35 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
16:38:35 Parsing UA reply succeeded.
16:38:35
7E A0 41 03 41 10 E4 8F E6 E6 00 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 31 32 33 34 35 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF 1C 3F 7E
7E A0 37 41 03 30 21 79 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 05 00 00 07 9D D2 7E
16:38:35 Parsing AARE reply succeeded.
16:38:47 Read object type Register index: 2
7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 03 01 00 1F 07 00 FF 02 00 DC 79 7E
16:38:47 Received data
7E A0 15 41 03 52 10 8F E6 E7 00 C4 01 C1 00 17 00 00 00 00 79 A7 7E
16:38:51 Read object type Register index: 2
7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 03 01 00 20 07 00 FF 02 00 85 83 7E
16:38:51 Received data
7E A0 15 41 03 74 24 CB E6 E7 00 C4 01 C1 00 17 00 00 00 00 79 A7 7E
16:38:56 Read object type Register index: 2
7E A0 19 03 41 76 1A B9 E6 E6 00 C0 01 C1 00 03 01 00 0E 07 00 FF 02 00 47 3F 7E
16:38:56 Received data
7E A0 15 41 03 96 38 0F E6 E7 00 C4 01 C1 00 17 42 48 00 0C 60 82 7E
16:39:02 Read object type Register index: 2
7E A0 19 03 41 98 6A B7 E6 E6 00 C0 01 C1 00 03 01 00 0C 04 00 FF 02 00 DD 2A 7E
16:39:03 Received data
7E A0 15 41 03 B8 44 C7 E6 E7 00 C4 01 C1 00 17 42 7E 08 BC 5C A9 7E
16:39:43 Send Keep Alive
7E A0 19 03 41 BA 7A B5 E6 E6 00 C0 01 C1 00 01 00 00 00 01 00 FF 01 00 50 0D 7E
16:40:04 Failed to receive reply from the device in given time.
16:40:04 Disconnect request
7E A0 07 03 41 53 56 A2 7E
16:40:04 Received data
7E A0 07 41 03 1F 26 EC 7E
9 years ago
Are you sure that this is EDMI MK6E.
Anyway. Select: Tools | Mnufacturers.
Change Keepalive interval for smaller. Try with 20 seconds.
Connection is closed because it's not used.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
