  3. RS485 Meter Addressing | Multiple Meters
By deepakdabas , 16 June, 2017
We have 2 meters connected through daisy chaining on RS485.
When we are using GXDLMSDirector with Physical Server Address 1, Both meters are working fine independently and we are able to fetch some data.
Our meter company has given the physical address as 255, 256 for 2 meters. When we entered 255 as physical address, GXDLMSDirector is not able to connect the meter.
Please suggest, how can we can connect meter through GXDLMS client by giving the physical address.
We need to connect through meter address so that only the marked meter respond the read command in case of daisy chaining.
Is it possible to get the address of individual meter if we connect using server address 1, so that we can verify the exact address of meter at run time.
9 years 1 month ago
You did not tell the manufacturer, so I have to give few hints.
Several meters are using serial number as a address on daisy chaining.
Can you connect with server address 256?
Can you try to change server address example 10 and then try to connect?
I know that there are some meters that can handle only one byte size server addresses.
deepakdabas
9 years 1 month ago
Thank You Mikko.
Thank You Mikko.
Can you please help me where to find server example 10
9 years 1 month ago
Multiple Meters
Sorry, I don't understand what you mean?
deepakdabas
9 years 1 month ago
I was not able to find meter
I was not able to find meter address server example that you mentioned in previous comment. Can you please share a link etc.
deepakdabas
9 years 1 month ago
In reply to RS485 Meter Addressing | Multiple Meters by Kurumi
Meter Addressing
Meter Make is Genus
Can you help how to give address in case of daisy chaining.
9 years 1 month ago
Can you change meter's physical address from 255 to 10 (or other smaller value)?
Then try again.
  • Georgerah
  • Pokiessearm
  • Rolling-Slots-Bok
  • OskoNadyLoold
  • @Hmd- several '.
