  3. Not Receiving Data From Meter
Not receiving data from meter
By bhargavdudani , 5 July, 2018
Gurux.Net
Hello Friends
I am trying to read data from smart meter used for gas , i am able to connect it with using GPRS but i am not able to read specific data from meter.
8 years ago
Can you tell more from the meter? Is that DLMS meter or something else? Are you using a static IP address?
bhargavdudani
8 years ago
1. We are using GPRS connecrivity and Dynemic IP and PORT
2. This meter is designed by Italy Company "MeterSit"
8 years ago
If you are using dynamic IP meter must always start a connection to the server.
You need to configure meter to make a connection to the server.
There is an "Auto connection" interface that allows you to do it.
If your meter is using Italian standard UNI/TS 11291-11 there should be no problem.
bhargavdudani
8 years ago
I have already connected meter with server using GPRS.
I can see meter is connected log. It show me message as below
8 years ago
In that case, I believe that you are using the static IP address on your meter.
I believe that your client or server address is wrong if the meter is not returning any data.
You should ask them from the meter vendor.
  • Thomasqto
  • Uka Ibe
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
