  3. Reading Profile Generic
Reading profile generic
By hanumaan , 5 July, 2018
Gurux DLMS for Android
Hi ...
I am.. try to reading profile generic data, below is the code snippet i have tried..
GXDLMSProfileGeneric gp = new GXDLMSProfileGeneric("1.0.94.91.0.255");
GXReplyData reply_data = new GXReplyData();
byte[][] temp = mClient.read(gp, 3);
for (byte[] it : temp) {
readDataBlock(temp, reply_data);
if (gp.getDataType(3) == DataType.NONE) {
gp.setDataType(3, reply_data.getValueType());
mClient.updateValue(gp, 3, reply_data.getValue());
byte[][] temp1 = mClient.read(gp, 2);
for (byte[] it : temp1) {
readDataBlock(temp1, reply_data);
if (gp.getDataType(2) == DataType.NONE) {
gp.setDataType(2, reply_data.getValueType());
mClient.updateValue(gp, 2, reply_data.getValue());
GXDLMSProfileGeneric gpScalar = new GXDLMSProfileGeneric("1.0.94.91.3.255");
byte[][] temp2 = mClient.read(gpScalar, 3);
for (byte[] it : temp2) {
readDataBlock(temp2, reply_data);
if (gpScalar.getDataType(3) == DataType.NONE) {
gpScalar.setDataType(3, reply_data.getValueType());
mClient.updateValue(gpScalar, 3, reply_data.getValue());
byte[][] temp4 = mClient.read(gpScalar, 2);
for (byte[] it : temp4) {
readDataBlock(temp4, reply_data);
if (gpScalar.getDataType(2) == DataType.NONE) {
gpScalar.setDataType(2, reply_data.getValueType());
mClient.updateValue(gpScalar, 2, reply_data.getValue());
first question Is this the write way to get profile generic data and its scalar values? or there is better way or readymade methods to read package recieved from the meter.
8 years 4 months ago
It's always better to read scalers and units before and save them an example to the file.
In that way, you don't need to read them from the meter every time again and again.
Bhavjinder Singh
8 years 3 months ago
Read meter on bluetooth
Hi...
Meter is giving data over bluetooth, how can i use gurux library
Hi Bhavjinder,
Yes, you can use bluetooth with Gurux lib.
You need to handle data reading and writing from bluetooth.
Deepanshu
7 years 8 months ago
While trying to fetch Profile Generic by using Gurux DLMS Android I am getting following error:
Read Capture Objects first. (Snap of error is attached)
Please let me know how to get around this error. Please provide the code changes required if any and where that needs to be done.
I believe that meter returns empty collection for capture objects. Can you read this meter with GXDLMSDirector?
Deepanshu
I am able to read all data of profile generic using DLMS Director. Please suggest how to do the same using app.
Deepanshu
