  3. GXDLMSClient Server Address Size 4 Wrong Order
GXDLMSClient Server address size 4 wrong order
By horcsa , 8 August, 2017
I've an existing Actaris Electricity meter system, that was installed by another firm so I've got only few information. I'm trying to listen into the communication throught the serial port and I see that the SNRM request is like this:
7E A0 0A 00 22 00 CB 03 93 69 CE 7E
I'd like to use GXDLMSClient to read data from the meters, but if I set the parameters like this:
GXDLMSClient client = new GXDLMSClient();
client.UseLogicalNameReferencing = true;
client.InterfaceType = InterfaceType.HDLC;
client.ClientAddress = 1;
client.ServerAddress = GXDLMSClient.GetServerAddress(17, 101);
client.ServerAddressSize = 4;
I send the SNRM request like this:
7E A0 0A 00 00 22 CB 03 93 55 0E 7E
Why is 22 value of the 4 sized server address is different?
What is the right way to handle this proble?
HorCsa
horcsa
9 years 1 month ago
I've changed the
I've changed the getServerAddress to return the bytes in the requested order and this seems to work form my application.
9 years 1 month ago
Hi HorCsa,
Server address is problem with older meters. What meter you try to read?
horcsa
9 years 1 month ago
It is an Actaris SL7000 (from 2008).
HorCsa
