By vamsi , 16 May, 2017 Forums Gurux.DLMS Hi mikko , I used gurux new release and did the basi changes of com /dev/ttyUSB0 and CGXDLMSClient cl(true) i am getting the below error InitializeConnection <- 07:13:26 7E A0 07 03 21 93 0F 01 7E -> 07:13:27 A0 1E 21 03 73 C3 7A 81 80 <- 07:13:27 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E -> 07:13:27 7E 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AARQRequest failed 258. InitializeConnection failed Invalid parameter.. if i commented if ((ret = comm.InitializeConnection()) != 0) { TRACE("InitializeConnection failed %s.\r\n", CGXDLMSConverter::GetErrorMessage(ret)); // return 1; } CGXDLMSObjectCollection Objects; if ((ret = comm.GetObjects(Objects)) != 0) { TRACE("InitializeConnection failed %s.\r\n", CGXDLMSConverter::GetErrorMessage(ret)); // return 1; } fallowing return 1 getting the below error InitializeConnection <- 07:14:42 7E A0 07 03 21 93 0F 01 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 <- 07:14:42 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AARQRequest failed 258. InitializeConnection failed Invalid parameter.. GetAssociationView <- 07:14:42 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <- 07:14:42 7E A0 07 03 21 51 11 E4 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 <- 07:14:42 7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <- 07:14:42 7E A0 07 03 21 91 1D 22 7E -> 07:14:42 7E 00 00 00 00 00 00 00 00 <- 07:14:42 7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E -> 07:14:43 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <- 07:14:43 7E A0 07 03 21 D1 19 60 7E -> 07:14:43 7E 08 00 00 00 00 00 00 00 <- 07:14:43 7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create Aborted please guide us to over come this error New release code Hi, You must read data until packet is ready. GXDLMSClient::GetData return DLMS_ERROR_CODE_FALSE if all data is not send. Check ReadDLMSPacket method. BR, Mikko New release code Hi Mikko , I checked with the ReadDLMSPacket method. I found the issue now its working fine with index 3 Thank you very much for your support. Thanks, pushpa from cyient team New release code Hi Pushpa, Nice to hear. Happy coding. BR, Mikko
New release code
New release code
Hi Mikko ,
New release code
Hi Pushpa,
