  3. Problem While Communicating Via TCP (Holley Meter DTSD545)
Problem while communicating via TCP (Holley Meter DTSD545)
By Sohail , 11 March, 2017
Hi Team Gurux,
First of all we would like to thank for your great effort to provide Gurux library.
We have successfully read Holley meter DTSD545 via serial port. Now we want to read same meter via tcp remotely, but little bit confused how we will identify the meter on the server i.e meter serial number.
Our meter is online and can provide server detail if you need.
Will appreciate your prompt response,
Sohail
9 years 4 months ago
Are you using direct TCP/IP, GPRS or do you have TCP/IP to serial port converter?
Ahmed Radwan
7 years 5 months ago
@ Sohil
@ Sohil
how you read meter on serial
could you send me the connection settings
Select "Holley Metering Ltd" as a manufacturer and set correct serial port settings.
Ahmed Radwan
I already did it in this way
I already did it in this way, but the issue is still.
I use optical cable ,
The meter can be connected using another software, this means that the cable is good and no issue in connection settings, but when i try to connect meter using your software, the connection fail.
Also, plz find my below screen shot.
Thanks in advance,
Ahmed
Can you get a trace from the bytes sent by other software? Client or server address must be different.
Have you checked serial port settings (baudrate, etc)?
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
  • highclassrightway
  • sapran
